Need help ASAP, TL misfiring in all cylinders.
Need some advice from some of you TL gurus on here. Last night as I was moving my car out of the carport to move my toy inside. The CEL on my TL turned on and stayed on. This morning I find out it was showing about 8 codes.
P0300
P0301
P0302
P0303
P0304
P0305
P0306
and last was P0174.
Which means all cylinders are misfiring. The thing is the car the exact same as always. NO bogging or shuddering throughout the rpms. The cel stays on so I'm not sure what to do in this case. I searched and read it could be bad gas , maybe even coil packs or spark plugs.
Just want to know what you guys recommend me to do?
Can I still drive her around?tia
P0300
P0301
P0302
P0303
P0304
P0305
P0306
and last was P0174.
101,000 Sorry should have included that in OP. Car is a 2006 6 speed with 101k miles. No timing belt done that i know of. Got the car from the 1st owner at like 88k miles.
chillten (08-20-2022)
Also how do I clear the codes?
I got these codes at the beginning of October to(didn't get P1074 though). I cleared the codes off and drove it to see if they would come back on or not after cycling through that tank of gas. 10 days later about 200-250 miles later and on a fresh tank of gas the same codes came back on. I felt that eliminated a bad tank of gas as being the cause. Both times it was only in the morning after sitting all night (garaged) and I had been experiencing rough idle recently for the first few mins upon start-up. And it drove fine.
I then took it to the dealer and had them check it out. All they found was the timing belt was "off one notch" and the tensioner needed to be replaced. It's been about 9 days now since then, I'm waiting to see if the codes come back or not. I'm not confident what they did fixed it yet. The rough idle has been better but not all gone since then and I can feel some light hesitation sometimes around 2k-4500 rpms. I also put in some injector cleaner last tank. Waiting to see if it makes any difference then to see where to go next. Hope that helps.
(08 tls 6mt 143k+)
(08 tls 6mt 143k+)
MIRANDA89 (10-22-2012)
FYI:
1. Disconnecting the battery will not clear the codes (DTCs). All that does is reset the MIL.
2. Most major auto parts stores with OBD readers will not reset the codes due to liability concerns.
Edit: Could have just been spurious. Only time/driving will tell. If the MIL doesn't come back on, then I wouldn't worry about it. Can't remember if the 2006 had a TSB for ECU reflash, you should check the TSB page.
Edit2: FYI, p0174 is fuel too lean on front bank, could be low fuel pressure, valve clearance issues, or injectors per the SM. Or could just have been a spurious blip.
The following 2 users liked this post by nfnsquared:
justnspace (10-22-2012),
So is there anyway to clear the codes without a obd scanner? As i dont have one.
Taking the negative battery cable off will clear it off the MID as nfnsquared said. And then as you are driving it if the issue reoccurs the ecu will identify the codes again and they'll pop-up on your MID again. Then you'll know if it was just a bad tank of gas or something else of a long list of possibilities.
^i would.
its a test.
you're testing to see if the lights come back on.
if the lights come back on, then you would know its something serious and then you can start to investigate further.
So, reset CEL.
drive.
if CEL comes back on, look into your coils and then spark plugs.
if coils and spark plugs look great, and you're still getting CEL,
THEN, investigate into the heads.
this is called trouble shooting.
its a test.
So, reset CEL.
drive.
FYI:
What do you mean by ECU reflash?
Also the guy at the auto parts store said that the p0174 code might be on due tue the misfires.
I've noticed my valves are a lot louder then I would expect, compared to my nissan maxima,with the vq35. Maybe she needs a valve adjustment?
I still think its an over-rev condition.
downshifting and miss 4th and put it into 2nd....
this would bend valves and would throw the CEL, saying multiple misfires. car would still drive normally.
the older years 04-05 had a TSB(Technical Service bulletin) for something going on with the ECU. the Dealers simply flashed the ECU to an upgraded version
Wouldnt bend valves show some kind of a sign?like smoking of some sort?
I had the same thing happen to me almost three weeks ago. The car is still at the dealer getting worked on. They replaced my spark plugs, coils, rechecked the timing belt, rechecked the valves, swapped the injectors out, performed a leak down test, and then determined its something in the head. Sent out the head and the valve guides on cylinder one were pretty loose. Replaced those and hopefully will be getting the car back on thursday. This honestly has me puzzled because I have an auto, there's no way I can over rev.
Just keep driving it. If the MIL doesn't come back on, chalk it up to a spurious event. Just as an aside, you may want to verify that water is not getting into the ECU (due to a plugged A/C drain tube).
So I stopped by my friends shop today before work. Hooked up the obd scanner and no codes showed up, not even any pending codes which he found strange. All I did was unhook the negative for about 10 min. Car still drove fine to work and no cels so far.
I doubt it. Our engines are somewhat notorious for the so called "valve noise", which may or may not actually be from the valve train. Also, our valve clearances so far are showing only a very small movement at the 105K point. I would not be the least bit worried about needing a valve adjustment at this point.
If it was due to an over rev, I'd assume you would already have had a repeat of the MIL. And with a 6MT, the only way you could have over revved it would be to miss a shift. You can't over rev it by taking it to red line under normal or hard acceleration. If you are certain you've never missed a shift, then I wouldn't worry about it.
Also what do you mean by water getting in the ecu?
now wait to see if the codes pop back up.
if they dont, you're good!
if they do, we can trouble shoot further.
P.S. there have been reports of the A/C drain tube getting clogged which then caused water to drip onto the ECU.
Where do I find this a/c drain tube at? Want to make sure its not dripping onto mine.
Not that I know of, unless the previous owner did. I bought the car when it was just shy of 30k almost four yrs ago. I practically over maintain my car because I do alot of highway driving and never want to run into any issues on the side of the road. Sorry OP Im not trying to high jack your thread or anything. Best of luck getting everything up and running again!
Check the passenger side carpet up for any wetness (up near the top left). See the picture in this post:
https://acurazine.com/forums/showpos...25&postcount=7
Hmmm.... that would worry me that there is a fault in the ECU or it has water damage. The codes (DTCs) should still be there. They are stored in non-volatile memory in the ECU and do not get erased by disconnecting the battery.
No, it's the A/C drain tube that causes the ECU problems (the one that causes the puddles on the garage floor in the summer). IIRC, it's found on the passenger side near the firewall (in the engine compartment). If it gets plugged, water backs up in the A/C housing inside the car and eventually spills out on top of the ECU.
It's been plugged by a spider's nest and also mechanically by oil change techs who didn't like getting dripped on (and then they forgot to remove it).
P0300
P0301
P0302
P0303
P0304
P0305
P0306
and last was P0174.
P0300
P0301
P0302
P0303
P0304
P0305
P0306
and last was P0174.
The following 2 users liked this post by One_silly_wabbit:
justnspace (10-25-2012),
MIRANDA89 (10-25-2012)
if you take the engine cover off you will see a aluminum plate on top with about 12 bolts and two nuts, remove those bolts and nuts and take the plate off, be careful not to pinch rubber gasket. if you look on the right (facing the engine) under the metal bracket which is secured by two 12 mm bolts there will be a pin hole about the diameter of a marker. if clogged stick close hanger and brake clean or carb clean and plunge hole until clear. it wouldnt hurt to blow it out with a chuck if possible.
