Need help
Old Mar 12, 2015 | 10:20 AM
teleisha's Avatar
Need help
My car has been hesitant to drive. I've replaced the tps a few days ago still the Same problem. Not to mention I didn't have the problem until my mechanic did a major tune up. Oil spark plugs, etc. I don't know. My battery went dead the other day. Would it cause my vsa light to come on? Btw the code that's showing on the computer is my o2 sensor. The tps code went away after replacing it. Please help!!
Old Mar 12, 2015 | 10:36 AM
well, let's see.
there's a code for an 02 sensor.
02 sensor might be bad.
Old Mar 12, 2015 | 10:43 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
You are going to have to provide more detail in order for forum members to help you:
Year and miles on car.
What does "hesitant to drive" mean? Always? Hot? Cold? Low speeds? Highway speeds?
What is your definition of a major tune up? Oil and plugs isn't really major. Did you have TB and water pump done?
"tps" -? Throttle position sensor. Typically referred to as APPS - Accelerator Pedal Position Sensor.
Anything else you can provide in terms of details will help us help you. You should also check out the 3G Garage if you haven't already - https://acurazine.com/forums/third-g...-first-553557/
