Navi DVD disc reading error Help !
Hi I have a problem sometimes when i start the car it appears on the Navi screen (DVD disc reading error please consult your dealer), and sometimes when i am driving it starts by itself and starst working !! some times it works fine sometimes not Will it helps if i go to a store and clean de CD ??? Anyone have expirience this problem ???
Just got the same problem this afternoon, it was working fine when I went home and when I got back to the car to leave for the night. There it is. Sucks if this will cost an arm and a leg.
Likely a problem with the drive itself. You can send them to Alpine for repair, costs about $150.
Dealer will not repair them, only replace them, and will change you $3,000 to do it to.
It's an internal fault in the nav. unit.
This gen. of nav. units have issues with the laser pickup heads.
If you have warranty, slide back to the dealer.
This affects all '06 to '08's.
Should be covered under basic warranty.
Take a close look at the disc, if it has circular scratches on it, then
you need a new nav. unit and disc.
If no warranty, get your check book out!
Hope this helps
Hope this helps
SidhuSaaB
05-30-2020 12:40 AM
Puma Jim
20
10-20-2016 11:59 AM
Pham Alvan
03-16-2016 09:17 AM
SUPRMN84
10-07-2015 09:46 PM
