My TL may have slung a rod through the side of the block!
#83
2009 g37s 6mt
I blew my motor toooo, having the motor replaced under warranty and pulling that bad boy off... hate to leave the club, but the tl cant handle it and im not building the motor either...
#85
type:::check it
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/supercharger-reliability-717081/
check that thread i threw something in there about SSMs motor
#87
lol j/k
did you have anything modded?
#92
A forged bottom end will prolong how long it takes to blow but it will still blow. Tuning is the answer. Detonation will kill even the strongest bottom ends eventually. I've destroyed a couple TRW forged pistons from detonation.
#97
Sounds like meth injection is the best way to go to prevent det with the s/c... I'm surprised C/T Engineering isn't addressing this problem. I don't know how hard you guys run your boosted TL's or the octane all of you are using but I say if it's approved for use it shouldn't cause failures like these.. JMO.
#98
runnin a little boost
I have found myself slowing down and letting people get a huge lead just so I can use the boost for more than a second. 4th pulls so hard, I too have been caught in the moment.
#99
Many of the people who boost their TL's are very hard on them. With all this Hp it is hard not to use it. If you drive any car like you stole it all the time, stuff with break, the blower just makes it easier to rip on.
But think about it this way. Cylinder pressure is what puts a strain on everything from pistons to rods to the crank. When you run into detonation, you're putting close to 2-3 times the cylinder pressure on everything. It would the equivilent to making 600-900hp worth of pressure on the internals briefly. That's why it blows without proper tuning. A steady 300whp with no detonation isn't going to hurt a thing.
#105
2009 g37s 6mt
I am looking into it, as i am going to get back my car today. happens that the head and valves blew along with the injectors.... THANK GOD ITS GETTING PAID FOR UNDER WARRANTY WITH A 200 DOLLAR DEDUCTABLE...
#107
you're lucky it was the top end.. make sure they replace your head gasket too.. heck I'd do a port & polish if they're just doing a valve job.
#108
If your injectors started leaning it out, you could've burned a valve and blown a headgasket. Just be prepared for the damage that might've already been done to the pistons and bottom end. I would ask to inspect the pistons while the heads are off. In fact, I wouldn't take the car back without inspecting it first. Very important. What's going to happen is a piston will eventually let go from the damage that's (possibly) already done and then they're not going to cover it a second time.
#109
thanks for the info. im picking up the S/C in two weeks but im not puting it on until i get all the info i need on it. im glad i came across this thread. where could i get one of those kits?
#111
2009 g37s 6mt
That sounds a little fishy. The valves can get burned but they can't "blow". The headgasket can blow but the head can't blow.
#112
That's good news. Sounds like it will live. Make sure to let us know how the meth works for you.
#113
2009 g37s 6mt
im gonna be easy on throttle for a bit, when i get it back, then im gonna consdier meth and where i am going to install it an etc, space is an issue, so i def wassna make it worth my while. SSMTL will live to whine again, and maybe get some rsx 330cc injectors since they can dump a ltlle more fuel.
#116
i see that you can.
http://www.365motorwerks.com/wateran...ctionkits.aspx
i was searching for some kits and i found this. do you guys recommend 1 or 5 gallon i dont see how the 5 gallon could fit with s/c taking up so much space.
#117
i see that you can.
#118
from d.c. to tennessee
hey what up
what up david,.. sorry to hear about the excursion. this is the first i've heard about it (been on a self vacation for last 6 months). good thing you didnt sell your car, you know you'd miss the whine. anyways im back, hit me up sometime.
navtool.com
31
11-16-2015 08:30 PM
STL TL-S
09-23-2015 08:52 PM
