my interior light not working
Hi all, I tried to change my trunk light to led, when i tried to took out the light bulb from the unit, I have no idea what I did that make all my interior light stop working. I turned them on, they not on. My remote alarm not working too. When I hit the open and close button it did nothing to the car. I'm so frustrated, don't know what going on with my car. By the way my car is acura TL 07
When the trunk is open, power would be on the trunk light. It is possible you shorted the bulb socket or wires together...the 12Volts to ground. Look at the lid fuse layout (should be under the dash left side...it is on my 06 TL) to find the fuse that powers what is not working. Check the fuse panel fuses and look for a open fuse. Before you replace the burned open fuse, make sure the wiring in the trunk is still not causing a short. (12volts to ground) If you see a fuse open replace it with the same amp value. Good Luck!
Hi
can you please tell me the details how did u fix this problem. After changing the trunk light bulb to LED, all my interior light stopped wokring including remote control and side door light. PLEASE HELP ME THX !
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
