My 08' TL blew all its Trans Fluid out and coolant
Dont drive it or you will need a new transmission and engine. Transmission cooler lines probably came out or something. Happened to my 08 last year... Got it fixed then had to do a bunch of drain n fills to get all the water out of the transmission.
All of the above
What do you mean transmission is blocked? If it's seized then yeah, no choice but to tow it to a shop and get a new transmission. Otherwise, don't drive it or even start the engine. Just get it towed to a shop and explain the situation.
And it's good you used large text. I can't see very well and that really helped.
I did not drive the car after that,
Looks like the radiator.
The hose (metal part) where the trans fluid entered/exits (passenger side) the radiator completely came off (not sure what caused it,pressure ) completely came away from the radiator.
i will try to replace the radiator today, should I buy OEM or aftermarket? Hope that the tranny is still good.
Coolant going into the transmission is probably bad..
also if the transmission fluid emptied out at the radiator.. that means no more transmission fluid in the transmission, also bad.
Get a DENSO radiator on Amazon. Same as OEM. Get 2 gallons of Honda/Acura blue Coolant and a few quarts of ATF DW 1 transmission fluid to replace.
The transmission is hydraulically controlled so no fluid = no movement. Yeah, try replacing the radiator and refilling the fluids before you take it in. If no-go, then I'm afraid to say that you've probably got a $3000+ transmission job ahead of you.
transmission external filter on Acura TL 2008?
Hello everyone,did anyone changed the transmission external filter on Acura TL 08’, and if anyone knows the part #? Thank you.
3x3 is enough or I need to do 5 to get all the coolan from transmission?
I think it takes 8.5qts to fill it up from empty. Check service manual to be sure. Do a 3x3 to get out as much coolant as you can. I would also flush the radiator to make sure that there is no atf in coolant. Maybe add an external cooler and magnafine trans filter while you are at it.
I was on the road when it happened to me in the middle of nowhere but we have CAA and got towed to the nearest city centre. After they figured out what happened, fixed the broken lines, replaced the fluid, and i payed 1200 bucks for this the car felt like a 4 cylinder. At the drive through I had to get the rpms ianto the 3k range just to get moving.... After doing all the extra drain n fills the power came back.
dallison
07-24-2017 08:36 PM
SilverBullet_RENAMED
09-12-2007 08:00 AM
SilverBulletCLS
09-30-2002 01:51 AM
2G CL Transmission Recall Q & A
09-23-2002 12:32 PM
