My '06 trunk doesn't work
Old Sep 30, 2013 | 11:49 AM
UA6 Baller Status's Avatar
Like the title says, my trunk doesn't work, what do you think it could be? Thanks
Old Sep 30, 2013 | 11:55 AM
in the glove compartment, there is a valet switch.
press it and see if that will help operate your trunk.
through the ski pass, you can also grab the trunk release to see if it will actually release.
Old Sep 30, 2013 | 12:01 PM
Slpr04UA6's Avatar
-------Tim-------
Is the switch in the glovebox on locked or unlocked. If its locked, remote won't open trunk!
Edit: Justin beat me to it!
Old Sep 30, 2013 | 02:59 PM
MandoTL's Avatar
^^ this
Old Oct 1, 2013 | 05:51 PM
No it's not that. Yes the trunk opens by grabing the trunk release through the ski pass.
Old Oct 1, 2013 | 10:25 PM
Will Y.'s Avatar
Registered but harmless
Check the dash trunk release button to see if it's connected to the wiring-- sometimes the connector is off or loosened during aftermarket or dash install work.
Old Oct 2, 2013 | 12:12 PM
noles.alum9's Avatar
Mine did this. Once we got it open through the backseat with a broom handle, there is a plastic piece on the latch that was broken.
Old Jul 30, 2014 | 04:06 PM
jkcutter's Avatar
7th Gear
Hello,
It might not be an electrical problem, at all.
My 2005 TL's trunk release became intermittent. When I pressed either the dash button or the key fob button, the release made no sound. I suspected an electrical problem.
After ensuring that valet switch in the glove compartment was ON, the owner of an electrical shop advised me to lubricate the release mechanism before doing any electrical troubleshooting. I didn’t think that would work, because there was no indication that there was any power to the release; but I tried lubrication anyway.
I filled all the cavities of the release with white lithium grease, and worked the mechanism back and forth many times.
To my surprise, that solved the problem. Now, the trunk opens every time.
Good luck!
AndrewS
19
Mar 14, 2024 06:59 PM
Ol'Dave
Sep 5, 2020 02:56 PM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
