Moonroof Vibration
Old Jan 8, 2010 | 03:58 PM
Etiedeman's Avatar
Moonroof Vibration
When I have my sunroof open in the moonroof position there seems to be some vibration on the forward part of the window, does anyone have a quick fix? It seems to stop when I apply pressure to the window at the forward position.
Old Jan 9, 2010 | 09:55 AM
Jesstzn's Avatar
You sure its the window itself? The sliding cover on mine will rattle if all the way back.
Old Jan 9, 2010 | 11:31 PM
smarty666's Avatar
your luck yours only happens when the sliding cover is back, I have had some sort of rattle, from day one, between the sliding cover and inside roof of the interior whether the sliding cover is closed or open
luckily, as long as I put a tiny inexpensive cushion in between the sliding cover and ceiling lining, the noise does not occur!!
Old Jan 9, 2010 | 11:33 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
There is a TSB out on this. Take it to your stealership, and they'll fix it for you.
(Or at least try).
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
