Misbehaving Electronics - troubleshooting?
'06 TL auto. The problem began on Sunday when the alarm would randomly trigger. it went off a third time. My TL was outside so i decided to swap cars and put it in the garage thinking the rain was doing weird things to it. after a day inside i was going to use the car and then noticed certain things were not working.
-Keyless Entry
-Power Door Locks dont respond but do actuate to the unlock position when a door is shut.
-Turn Signals
-Park Lights won't work unless switch is in headlight on position.
-Wipers only work at one speed. Mist position does not work.
-Outside Air Temp reads '---'
-Dome lights behave randomly dimming and then turning on.
-HFL works normally.
i took the car battery in to be tested and the results were borderline. i figured since it was out i'd replace it. cleaned terminals and clamps reinstalled and the problems still persist. all fuses under dash and under hood check OK. the car went without battery power for about an hour when i ran to the parts store for a replacement.
my question is if there's anything else that i should try or look out for before i take it to the dealership?
TIA
-Keyless Entry
-Turn Signals
TIA
dude i had the same exact thing happened to me this morning!!!!! my battery is new, just replaced it a few months back, i bought one from the dealer... i also tried disconnecting the battery n letting it sit but the problem is still there... one thing i noticed is that my front driver side marker is very dim, and my windshild washer nozzles arent working either!!!!! i just worked a 17 hr shift n just got home so im gonna get some rest now n ill look into it later....let me know if u find a solution.... GOOD LUCK!
-Keyless Entry
-Turn Signals
TIA
-Keyless Entry
-Turn Signals
TIA
Check the passenger side carpet at the firewall for any moisture.
""""My TL was outside so i decided to swap cars and put it in the garage thinking the rain was doing weird things to it. """"
thats weird you mention that, i was working valet at a private party n my car was park at a bridge over a creek, it was barely raining but there was a lot of fog in the area which was well surrounded by huge trees..
bigg_86 what did the dealer say. I'm having similar issues on my 04. Will check fuses like mentioned above and for moisture also. Car sits outside and was covered by snow from the recent storm.
I am having this same exact problem, just started today. I have an 05 TL. Dunno wtf is going on with this pos car, but I've lost all respect for Acura when a car like this has this magnitude of failure. I'm already dealing with my driver's side actuator not working. I can't even drive this car now since it appears my rear defrost doesn't work either.
Things not working:
Fog Lights will not work.
Dash headlight indicator is out, but headlights turn on.
TURN SIGNALS DO NOT WORK.
Outside Temp Gauge is out.
Windshield wipers only work on max.
Gauges do not toggle between MAX BRIGHTNESS and normal brightness when I turn on the headlights - almost like the car doesn't know the lights are on.
This is complete BS, and shouldn't be happening.
Probably are other things not working, but that's the big stuff I've noticed thus far.
Things not working:
Things not working:
Things not working:
I have, and they are bone dry, look just fine. I was initially concerned that perhaps water had gotten into one of them, but they seem just fine. Took a long hard look at both of them and can't see any issues. There is definitely something jacked up going on at some central location in the electrical system though - has to be to effect so many functions. Also, just tonight again everything is working fine. It's been raining hard here the last few days, but that's nothing unusual for washington state, and I can't explain for the life of me why all of a sudden this car would develop these issues.
this is basically the same thing that's happening with mine too, just started acting up randomly this past week.
let me know if you guys find a fix, otherwise i'm forced to go to the dealer and i really don't want to do that.
Jamus22
06-11-2023 10:08 AM
Eggs999bacon
09-24-2015 10:08 AM
