memory loss
Old Mar 12, 2010 | 03:08 PM
saltysteve's Avatar
memory loss
hey i have a memory loss problem. my seat 1 and 2 buttons work but the car doesnt remember anything. it doesnt remember the garage door opener either.
anyone know what the problem is?
all buttons light up when pressed so i dont think its a fuse but im not sure. please help me out!!
thanks!
Old Mar 12, 2010 | 03:37 PM
nfnsquared's Avatar
Is your washer inop and the green light in the rear view mirror out? Then it's fuse #20.
http://www.in.honda.com/Rjanisis/pubs/SB/b05-033.PDF
Old Mar 12, 2010 | 03:58 PM
saltysteve's Avatar
YES THEY ARE!!!!!! Thank you ! you have made my day - im going to check it out right now!! hope this works
Old Mar 13, 2010 | 11:16 AM
saltysteve's Avatar
Hey man thanks a million!! that worked! everything is working perfectly now
Old Mar 13, 2010 | 10:57 PM
nfnsquared's Avatar
Anytime!! I come from the school of "been there, done that"
Old Mar 13, 2010 | 11:45 PM
gungrave's Avatar
How about if memory loss is present but those lights you described are fine? Becouse on mine i have the (memory loss), (light not lit on the shifter console during nighttime) and (mode light not lit on steering wheel and left seat heater button light not lit during nighttime) thanks for your help.
Old Mar 14, 2010 | 01:51 PM
nfnsquared's Avatar
OK, I'm a little confused about your problem. I only mentioned one light. Does your windshield washer work? Are you sure you have memory loss? I'd still check the fuse. There is a TSB for the seat memory module to be replaced, but I think it's just for '04.
The other part sounds like burned out bulbs that need to be replaced.
Old Mar 15, 2010 | 10:53 PM
saltysteve's Avatar
okay maybe you can help me out with one more?
i have a trunk light out. i have replaced the bulb but still nothing. a fuse maybe? and where could i find it?
Old Mar 15, 2010 | 11:26 PM
nfnsquared's Avatar
Fuse #6. might be a bad plug to the light. check it for continuity. Could also be a bad trunk switch.
Old Mar 15, 2010 | 11:31 PM
saltysteve's Avatar
nice thanks again!! ill check that out in the morning
Jul 16, 2017 07:33 AM
nj2pa2nc
Aug 19, 2016 06:18 AM
ceb
ILX
Sep 27, 2015 10:56 AM
Rcelestino93
Sep 23, 2015 10:01 PM
