Major Problems with my 04 Tl
Old Sep 10, 2007 | 04:41 PM
LEOKOHEN's Avatar
5th Gear
Unhappy Major Problems with my 04 Tl
Good Afternoon to everyone,
My tl seems to be dead, Driving on the highway my car started not to respond to full throttle. about an hour later i stepped on it and it stalled completly would not start. So i towed it to my mechanic two days later the car starts now the car would not go over 3,000 rpm's my mechanic thinks ot might be the timming belt moved over it does not move when i floor it the cars has about 76k I drive my car really hard. I need some help here. The check engine light turned off after the battery died. Also when I turn the a/c on the car goes down to 500 rpm's and shakes, it started to do this 3 days before I had problems
Thanks in advance
Old Sep 10, 2007 | 04:46 PM
timmahh's Avatar
it's me, Alan Rickman.
Might want to check throttle / gas pedal sensors.. Toyotas w/ drive by wire will go into "limp" mode when a problem is detected in the drive by wire system and I think the system limits the engine to 1800 RPM.. maybe your car is doing the same thing.
If there is a bad sensor and the engine is running low, then putting a load on it (a/c) may cause it to idle even lower.
So the check engine light is off and will not come back on now?
Old Sep 10, 2007 | 04:50 PM
The Dougler's Avatar
Unofficial Goat
take it to an acura mechanic, they will scan and report back.
Old Sep 10, 2007 | 04:52 PM
LEOKOHEN's Avatar
5th Gear
no it wont come back on now. I think its a sensor but here is million sensors to check with no code I have a problem. its wierd i think the car is in a safe mode or something
LEOKOHEN's Avatar
5th Gear
but if there is no light there is nothing to scan
Old Sep 10, 2007 | 04:54 PM
BLACKURA_NY's Avatar
I have car ADD
lol.. theres no "safe" mod for cars...
as for the 500rpm.... thats idling low.. could be many things, first thing i think of is a plug.
car not moving when you press the gas?? elaborate please.... does the engine rev, to what RPM, etc,etc.... usually, when a car doesnt "move" we think transmission problems....
good luck..
p.s. go to acura. they know their shit the best. i have my mechanics, but when it comes to big important things, you are better off safe @ acura
Old Sep 10, 2007 | 05:00 PM
LEOKOHEN's Avatar
5th Gear
my tarnny got replaced 15k ago thats out of question it would not go over 3000 rpms
Old Sep 10, 2007 | 05:01 PM
timmahh's Avatar
there is a safe mode for cars.. like what i described above; if the vehicle detects a problem with it's drive by wire system it limits engine speed.... it's not like pressing F8 on a computer or anything but it is a safe operating mode... (though driving 10 mph may not be safe on the road..)
Old Sep 10, 2007 | 05:21 PM
CL Platano's Avatar
Tristate ViP Crew
Ecu
Old Sep 10, 2007 | 05:35 PM
Kennedy's Avatar
OMGWTF4THGENTL
Timmah's correct. The car will go into "limp mode" to preserve itself if it senses certain anomolies in the numerous sensor arrays. What the OP describes in the opening thread is almost a perfect example of what your car going into limp mode feels like.
As for the OP's question, just becasue the CEL isn't on doesn't mean there isn't a code stored in the ECU. The flag that triggered the original CEL will be stored as an "intermittent fault", which wil likely lead you to the source of the problem.
Can you tell I used to drive a VW?
good luck..
Old Sep 10, 2007 | 05:43 PM
I have car ADD
lol. if you had an 07+ i think the Acura link will tell you whats wrong with the car!! lol
could very well also be somethign to do with engine management (ECU) or on O2 sensor... but, i am not a mechanic... the guys @ acura are.
Old Sep 11, 2007 | 01:25 PM
Kennedy's Avatar
OMGWTF4THGENTL
I drive a 2006... which is virtually the same car. 07+ have a later version of navigation, a DVD player that plays mp3, and a BT module that will pull contacts from "certain - Sony Ericcson almost exclusively" phones... that's about it... ain't nothin special or different about the 07+.
AcuraLink is Acura's marketing speak for an integrated Nav, Bluetooth, and handfree system... Just like all of us have from 2004 on (if you elected Nav). AcuraLink will not read out trouble engine diagnostic codes... and should not be confused with the ONStar feature that does do exactly that.
I'm not a mechanic either... but I'm savvy enough, and been around this stuff to know what's up.
- Something with the ECU... Um yeah. It's just that, an ECU that processes numerous signals from the sensors. There's a fialied sensor somewhere... and it must be a serious one, enough to send the engine into limp mode.
- O2 sensor it's not. Those fail all the time, and will creat CEL, but never send the engine into limp mode.
Careful attention has to be paid to when to trigger limp in the ECU SW programming. The safety issue of limp mode while driving vs the safety issue of catastrophic engine failure must be weighed. Minor exhaust issues are not one of those.
Old Sep 11, 2007 | 02:07 PM
Kennedy's Avatar
OMGWTF4THGENTL
I stand corrected, Acuralink will display a limited set of trouble codes and convey those to the nearest dealer... That's pretty neat...
Old Sep 13, 2007 | 05:38 PM
LEOKOHEN's Avatar
5th Gear
Good News,
Thanks to everyone for th input, it was my catlytic melted blocked the exhaust so I gutted both of them I get my car tommorow tell you guys how it rides time to upgrade the TL CAI,UNDERDRIVE,NOS, COMING SOON
Old Sep 13, 2007 | 06:54 PM
TL_moda's Avatar
It's no limit Baby
Originally Posted by LEOKOHEN
Good News,
wow i never heard of a catalytic melting before,crazy shit
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
rboller
Sep 23, 2015 02:49 PM
