Major or Minor Brake problem
Old Aug 8, 2009 | 05:38 PM
xtmjoey's Avatar
So, I just changed my oil today went to synthetic...GREAT!, but now, not a few hours later I'm going somewhere and my rear brakes (or what i am assuming are my brakes started absolutley screaming!!!!) so on the way home to try and dianose whats going on, i go to press the brake pedal and it feels like theres no resistance at all the brake pedal went all the way to the floor!, so am i in deep here, maybe just need new pads or in all of your experience am i in deeper than that!, please help, is this something i can fix in my garage quickly?, or do i need to get it to a dealer?
thanks in advance
Old Aug 8, 2009 | 06:38 PM
Turbonut's Avatar
If the pedal went to the floor.....not good. Low/worn out pads aren't going to cause the pedal to drop to the floor. Check the fluid level at the master cylinder to see if low. If low look for leak, calipers, lines, master cylinder. Look through the wheels at the rotors for any grooves.
Old Aug 9, 2009 | 01:14 PM
mlassek's Avatar
one of your rear caliper slides is locked up causing the soft brake pedal. the noise sounds like the wear indicator scraping the rotor.
Old Aug 9, 2009 | 07:07 PM
xtmjoey's Avatar
ok thanks that explains it, I checked my fluids and all is well, topped it off anyways, so looks like just a set of new pads and all will be ok?, bad thing is this happened late sat night as you know no shops are open on sunday so another day of wait for me, thanks to both of you for your input, I greatly appreciate it
tman570
Jun 11, 2019 07:56 AM
pstomps
Feb 20, 2017 03:29 AM
asahrts
Sep 4, 2015 05:55 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
