Major electrical problem
Old Feb 27, 2013 | 12:25 PM
pmak23's Avatar
So sometimes I unlock my car get and start to turn the key and the whole car loses power, nothing has electric at all open and close the the door and it has power. Last week the car was saying my back right door was open BUT when I had my seatbelt on was saying it was closed. Today I have no turn signals, and my headlights are on but no symbol on the dash and the car won't lock or unlock while on but then I turn it off and it displays the car has the headlights on on the dash and let's me lock it. Then other times I shut it off and it has no power and I have to manually lock the doors. Does anyone have any ideas what could possibly going on I'm completely stumped.
Old Feb 27, 2013 | 01:15 PM
Will Y.'s Avatar
Registered but harmless
Check the battery cables and ends-- both cables can corrode, and the negative clamp tends to loosen up over time. Some members had issues with the ground side of the negative cable as well. Clean the cables or replace as necessary.
You might also consider testing the battery and getting a new one if it's more than 4 years old.
G/L.
Old Feb 27, 2013 | 02:37 PM
pmak23's Avatar
changed battery 2 months ago and just tested the alternator. i have no turn signals right now so this needs to get fixed today.
Old Feb 27, 2013 | 04:11 PM
GKinColo08TL's Avatar
Check for leak at sunroof into HFL module...read on a thread that if this happens it screws up all the electrics. Good luck.
Old May 5, 2013 | 05:04 PM
phantom99's Avatar
I started having the loss of power on turning the key and found the door trick. Have you found the fix?
Old May 9, 2013 | 06:12 PM
phantom99's Avatar
OK, found it! First thing I checked was ground battery terminal and, sure enough, it was loose. My bad: sloppy job tightening the terminal when I put the car back on the road April 1st. The problem appeared after a few weeks.
Old May 13, 2013 | 07:59 AM
pumafide's Avatar
sorry to go of the top. but i,m having probs. with my door locks dome light and clock.i was trying to add a pressure switch under my subwoofer box and blow a fuse.now nothing works inside the car.could it be a relay or am i having wiring probs??
Rachel Lu
Sep 27, 2015 09:53 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
Aug 30, 2015 02:39 PM
