Lumbar Support Problem
Old Oct 21, 2010 | 10:13 PM
rockstar143's Avatar
Question Lumbar Support Problem
Problem: I hear it inflating/deflating but it is not actually filling up the "bag" that adds the lumbar support. Did something get disconnected in the seat?
Anyway way at it without damaging the seat?
Thanks in advance all!
Old Oct 22, 2010 | 02:47 AM
libert69's Avatar
18psi
If you figure it out please let me know. I always have the lumbar set to full and one day it just popped and went flat. It wont fill up anymore lol
Old Oct 22, 2010 | 10:12 AM
boosted1993fd's Avatar
9th Gear
I have the same problem on my 07 RDX.. interested on what could be the issue.
Old Oct 22, 2010 | 11:03 PM
My guess is it's a miniature pump inside the seat connected to a bag that inflates...from what I can hear either the hose connecting the pump to the bag got disconnected OR the bag itself popped and is just letting the air escape. I can hear hit a "full" point where it stops pumping and a low point where it would be empty. I don't get it. I'll have to see...looks like the hard plastic on the back of the seat probably opens up to reveal the insides.
Old Oct 23, 2010 | 08:45 AM
nfnsquared's Avatar
Old Oct 23, 2010 | 09:51 AM
Thanks man...much appreciated. I'm guessing I can pull the back portion of the seat off while in the car?
Doesn't show how to get at it, but at least now I know where it is!
Old Oct 24, 2010 | 09:35 AM
Ok, tried prying the seat back off...it doesn't budge so that can't be the way in. I don't know how else to get at this mechanism to check it out.
Old Nov 4, 2010 | 08:54 PM
Ok for all those with LUMBAR support problems, here is your fix.
A) Do NOT adjust lumbar while resting on it...it will break the plastic that the support rests on.
If you can hear the motor working but no support, this is your fix. Maybe it can be put in the 3G garage as we are tackling problems as they happen as our cars get older.
a BIG thanks to:
donnieb83 for the pics and pointing me in the direction of mmade's thread on installing a headrest tv. It showed me what I needed to see for the lumbar support.
Bascially, with 10 minutes and 3 tie wraps, you can knock this out. 2 for support...and 1 to keep the lower piece on the track. Check images. You have questions, PM me...
Thank you.
Old Nov 4, 2010 | 09:09 PM
1islandparadise's Avatar
+1 for the 3G garage. Looks like several members are having the same problems. I'm glad you got it working! Who would have thought....3 quick zip ties to fix...lol. Nice job man
Old Nov 5, 2010 | 06:54 AM
Thanks man...again, had you not provided that info, I wouldnt' have figured out opening the seat OR what the lumbar support was supposed to look like and how it worked.
Either way, this will be good to share with others, I think.
Old Nov 5, 2010 | 08:00 AM
dwb993's Avatar
DEFINITELY Garage this!
Thanks, rockstar!
Old Nov 5, 2010 | 08:35 AM
Anytime man, glad I could share/help!
Happy Friday all!
Old Nov 5, 2010 | 01:07 PM
space_bound's Avatar
How do you get into the seat?
Old Nov 5, 2010 | 04:54 PM
At the bottom pull toward you...then lift up...the seat back
Old Jan 1, 2011 | 05:18 PM
OnTheClutch's Avatar
So my lumbar makes a clicking noise at the lowest level. Did you have that? Also, do you have better directions on getting the seat back off?
Old Jan 1, 2011 | 07:26 PM
So my black frame is not broken. The cable is not moving at all. The motor is running, but not moving the cable. I will likely replace the whole motor and cable assembly.
Old Jan 3, 2011 | 05:58 PM
open it up before spending the money...if motor has juice and is making noise and TRYING to move cable...then there is probably nothing wrong. It probably has just pushed the cable out of the mechanism...
Old Jan 7, 2011 | 12:10 PM
I will test your theory tonight. I like the idea of saving $150. It worked about a month ago, so i hope it is just the cable being off track.
Old Jan 7, 2011 | 12:12 PM
It feels like it will not move, but it will. once the bottom is out. the next 2 clips are half way up the seat back, then it slides down and out easily
Old Aug 27, 2011 | 07:19 PM
Success^^^
Sorry, just saw there was a reply on this thread. Figured I'd bump in case anyone is having issues.
Old Nov 10, 2011 | 06:36 AM
Ok...so a year later and WAIT FOR IT....WAIT FOR IT....
It's broken again...but this time the bottom part of the plastic snapped. I need to see if this is something we can order. Anyone know if you can get the lumbar portion alone?
Old Jan 15, 2012 | 09:49 PM
Ok, so after finding out the part is $180 and you have to remove the seat to get it changed...NOT an option. So, today I took another stab at it. Not bad...I'll have to revise it tomorrow.
Basically I dremeled a little area up top to keep the metal support flat beams from popping out of the top, and tiewrapped the shit out of the broken bottom support. It presses back into the lumbar support so it still works. Great! I also had to pull up and tie up the metal cable tighter to get it to put enough tension on the assembly. Hopefully this holds up!
J.
Old Jan 16, 2012 | 05:08 AM
ohsixMTee's Avatar
Early Shifter
Normally I hate lumbar support but I do have mine inflated some what and find it very comfortable to our already comfortable and relatively "hugging" seats.
Excellent information you provided!
Old Jan 16, 2012 | 01:16 PM
Thanks man...
I need a break from the car. Will post up pics later.
Old Aug 13, 2013 | 08:18 PM
Fkwallace2's Avatar
5th Gear
I understand you're the man to see as it relates the lumber support in a acura tl? Only thing is there's no pictures or they've been removed, would you happen to have them or could you reported them? Let me know either way. Thanks in advance
Old Aug 13, 2013 | 08:44 PM
guitarplayer16's Avatar
https://acurazine.com/forums/showthread.php?p=14598494
Old Aug 14, 2013 | 12:32 PM
Thanks, Thanh. My photobucket is being a hoooahhh these days.
Old Jan 31, 2014 | 08:03 AM
seanpatrickjones1's Avatar
Thanks for the post! Just zip tied to perfection!!!!!!!!!
Old Jan 31, 2014 | 08:44 AM
man...
I think my motor has either gone, or the ties are broken now, but it did last for a long time! Plus, it's comfortable as it sits right now.
Old Oct 17, 2015 | 08:46 PM
Sam Djtjuas's Avatar
Hello how do you remove the back panel to access the location to add the zip ties
Happy Friday all!
Can you please tell me how to get access to this location
Old Apr 10, 2016 | 10:29 AM
icedT's Avatar
Lumbar support.
This works: The '05 TL lumbar support is not pneumatic, it is a plastic bending part that uses metal leaf springs for support but come up short at the bottom where the plastic, especially after a few years and pushing hard against it from ingress/egress/dead pedal leg extensions, will fracture. The back of the seat is held by two clips at the bottom and translates up and out when the clips are pulled/broken - and must be replaced. Repair of the lumbar fracture requires more than epoxy (tried that) since it's under both bending and shear stress. Simply splice plates on each side with both epoxy and mechanical fastening (here - rivets).
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
