Low IDLE problem
Old Feb 17, 2006 | 09:18 PM
xedap1998's Avatar
Low IDLE problem
Car is warmed up....stop and turn off the engine for 10-15 mins....turn back on...shift out of neutral the engine RPM drops low to about 550 RPM and stay there for a few seconds...3-4 seconds...feel a litttle shake and feel like the engine going to stall...even if shift out of P into neutral...anyone has this proble??
Old Feb 18, 2006 | 02:55 PM
Ron A's Avatar
Administrator
I don't remember seeing this problem, but it doesn't sound good. Do you get a check engine light?
Either way, if it is a recurring problem you should let the dealer check it it out. Maybe the computer set a code that will tell him what's wrong.
Old Feb 24, 2006 | 02:48 PM
BATTLESHIP's Avatar
Question Low Idle
WOW! I've had the same problem! It dosen't happen every time...in fact, it only happens to me when it's parked outside during cold weather... not when its parked in the garage and running.............
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:14 PM
