Loud noise braking before I park car??
Ok. I have a scheduled appointment with my dealer this monday. My problem is when I'm turning slowly under 5mph when I'm about to park or even I make a U turn I hear this loud noise (possibly my front brakes). Its different from the sqeek noise when you brake. I have no idea what it is. You think this is a big issue? Has anyone experience a similar problem when you are turning and breaking under 5mph. Its very loud and I never had a problem with any cars I drove before. Thanks.
Originally Posted by ndx2
could be a problem with the serpentine belt.
Good point.
Notice any leaks underneath up front?
If it happens when you turn and max/lock the steering to either side it could be a power steering/rack-n-pinion issue. Check to ensure your power steering fluid is at the proper level. A low/dry power steering pump makes a heck of a racket.
Keep us posted
Originally Posted by rventu
Mine happens when it's still rolling and the noise stops when I let go of the brakes.
If it makes noise all the time, go to the dealer - they should replace it under warranty.
Ok, guys. I went to the dealership. I had my service rep drive the car. For some reason it would not make the noise as he slowly turned and park. I then tried driving the car and parking it. No luck. Well drove around and when we returned to the dealership it finally made that loud noise right before I came to a sudden stop. He said that this is caused by brakedust buildup. He told me if it continues we will check it out when you have your 1st oil change. He also said its not a big concern. I now have 2000 miles on my car.
2012wagon
Sep 29, 2015 04:21 PM
