loud engine already!??
Old Jan 21, 2007 | 06:39 PM
tl-typeS07's Avatar
it has only been less than 20 days after i purchased brand new 2007 type S. and the engines already loud with constant clicking sound. so i compared the engine sound wit my friend's 05 tl and my friend's car was way quieter than mine. and to that i have never gone over 70mphs and over 3rpm with 700 mileage, also i warm up or not shift from P till the temperature gets to mid. maybe due to the coldness here in nyc? some1 please tell me wether this is normal or not and if this can be fixed!
Old Jan 21, 2007 | 08:39 PM
subinf's Avatar
One on the right for me
So I'm assuming that the engine was quieter when you bought the car?
Old Jan 21, 2007 | 09:40 PM
tl-typeS07's Avatar
yes. and no clicking sound either.
Old Jan 22, 2007 | 07:53 AM
drdug27's Avatar
you cant compare the cars 2 different engines.
if its loud bring her in...the cars under warranty and also brand new(there are bugs)
i had to brung mine in for rear struts already
Old Jan 22, 2007 | 03:59 PM
csmeance's Avatar
most likely it is because the oil is still fresh and probably has some metal shavings which is normal. After the first oil change, it should quite down.
Old Jan 22, 2007 | 07:12 PM
tl-typeS07's Avatar
ooo thx to you csmeance, i shall no longer be worried about it
Old Jan 22, 2007 | 10:28 PM
Will Y.'s Avatar
Registered but harmless
Nothing should be clicking-- if metal shavings are clicking, we're talking serious issues here!
Originally Posted by tl-typeS07
... i shall no longer be worried about it
See the dealer and have the service department listen to your car. Also listen to another TL-S or two on the lot have that clicking sound. If the noise isn;t present in those, you could be bad belt, bad accessory bearing, valvetrain noise, etc.
Old Jan 28, 2007 | 04:24 PM
tl-typeS07's Avatar
ok, i've changed my oil change at 2k miles, and csmeance was right, the car sounds much quieter! i think its even quieter than when i just picked it up at the dealership!
Aug 15, 2019 12:58 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
batheesha
Sep 19, 2015 09:51 PM
Sep 15, 2015 06:44 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
