Locked engine won't crank-HELP!!!
Two days ago my car started miss firing I checked all sparkplugs, ignition coils and everything was fine so I went on with a compression check and one of the cylinders came up with 0psi, I called a few friends and they all said it was probably a clogged valve so I did the seafoam treatment but nothing happened, yesterday night as I was heading home it started miss firing more until it turned off I tried to start it and it would crank but not start, after a few times of trying it started but I couldn't let it drop under 2k or it would turn of I drove about 5 miles like that until I heard a big clanking noise and the car shut off and now it won't even crank the engine is locked, this morning I removed the 3 front spark plugs 2 of them were filled with oil and one was all torn up then I removed the intake manifold and it was filled with oil mixed with water and had a few pieces of metal in it, let me know what you guys think I really need help on this to decide what to do. Sorry for spelling I'm writing on my phone please help!!
Dogmatic Dinosaur
So many things could be wrong
Could be a broken cam, valve, value spring, piston, piston ring, cracked head, etc... or a combo of any of them. No way to know until you get in there.
You are going to need to take off the valve cover and have a look at the cam, springs and valve stems and inspect the head from the top end. If that all looks fine, then the head is going to need to come off, but it is probably going to need to come off anyway.
Unless you are under warranty, then this is not going to be cheap. Sorry.
I've never over reved it but don't know of the previous owner did?? ill be removing the heads this afternoon see what's wrong, is there any chance it went off timing, and if there's any bent rods or cracked piston what do you guys recommend getting a new engine or rebuild this one
Uploaded with ImageShack.us
Things are way worse than i thought, its time for a new engine
You threw a rod. Notice the missing piston lol. Engine is junk. Replace entire engine. If you're lucky you can reuse the heads after rebuilding and resurfacing.
You drove the car around with 0psi on one cylinder, what did you think would happen? There's no such thing as a "clogged valve".
You've got part of an oil ring sitting on the head, a piece of wristpin and rod and 1/4 of the piston ring land area sitting on the crank. There's most likely a hole in the block where part of the rod exited but maybe not since the top of the rod is still inside of the engine. Just the fact that the piston top and top of the rod are sitting on the crank, you might've broken the crank too.
If it's locked up it would be all of those broken pieces wedged between the block and the crank. Highly unlikely anything is usable. After seeing the huge gash in the head, it's not usable either. More than likely you dropped that valve into the combustion chamber, kept driving until it destroyed the piston which let the rod self destruct.
tomorrow ill be bringing down the engine i found a j32a3 in a local junkyard with 65k theyre asking $900 for it, i havent seen it yet but i will come by the place tomorrow and take a look at it. what do you think? is it worth repairing? most of the valve was inside the intake manifold
For a rebuild you're looking at:
At least one replacement fully dressed head.
At least one piston, pin, and ring set.
At least one rod.
Gaskets and misc along with machine work and labor which is extensive.
That's the absolute best case scenario. Most likely you will need a new block and about 50/50% chance of a new crank depending on whether or not the big end of the rod held together. There's also the chance that everything exited through the oil pan.
i guess my best choice is to go with a new engine. im pretty sure any engine i find came of a AT Tl would i have to change the wiring on the engine
my yard looks like a junkyard lol. so i went and bought this engine it came off a totaled 04 tl it has about 65k on it and 90 day warranty what do you guys think?
iWhine S/C 6MT TL
You know with 0 psi you should have heard "some" metallic noise before the engine gave out. Either way with the new engine you should do the timing belt with water pump and tensioner while it's still out of the vehicle. T-belts due every 6 years or 105k.
im also going ahead to order new engine mounts (still deciding which to go with) while i wait for them to arrive ill be doing a full service to this engine to make sure nothing goes wrong once it starts
so today i got the engine out i spent about 8 hours to remove it, tomorrow ill be putting the MT wiring and will be swapping the transmission
Keep us updated!
Nice find on the new engine =)
im guessing it had to be hydrolocked, because what else can cause a damage like this when everything was working perfectly. The missfiring started one day when i turned it on in the morning and from there 4 days later this happens, but it has been raining alot these days, if it were hydrolock wouldnt it happen instantly?
It might have dropped a valve down into the cylinder which would give you 0 compression then you kept on driving and it broke the piston which let everything loose.
Or detonation. Do you run premium?
Honestly you can see what looks like the imprint of an intake valve and seat in the head. It really looks like you hurt the valve first and the valve took out the piston. Anytime you have 0psi and no noise it's almost for sure valvetrain related. It's hard to get 0psi with a damaged piston unless it has a hole in it which usually makes noise. You can break a ring and ring land and compression will be very low but usually not at 0.
yes i always run premium, i think the problem was what your saying a broken valve that fell into the cylinder and i kept driving the car and thats what caused the piston to break and lock the engine
Dogmatic Dinosaur
You are fortunate to have the time, inclination and ability to do this swap, otherwise you could be looking at 3-5K, or more.
My guess is that the an over-rev from the past did some damage and only recently broke all the way. I guess that it could have been a zero clearance valve issue with perhaps a broken timing belt in the past. In any case, this is perfect evidence that issues can arise down the road when metal gets with metal. Anybody who broke a timing belt and did not pull the head to have it fixed/checked, this could be in your future.
Could have been poorly adjusted valves too.
CTS-V Import Slayer
yesterday i went by P2R and got a set of ported runners and ordered a motor mount kit from innovative they'll arrive tomorrow thats all i need to mount the engine
yeah.. I think I see your problem.
Keep us updated.
Keep us updated.
here are some pics of the runners my kinda worn clutch and the oil ill be using with new plugs
AZ Community Team
Received 7,770 Likes
I prefer 5W-30 as well.
I like the idea of a slightly heavier film. I also subscribe the "5W-20 is for CAFE" theory.
BTW-check out the new site I am helping Drew with www.nnstudios.com/thepitshop_devdeploy/ That's how much I am standing by this guy.
Such a touch subject - everyone swears by some brand or weight. But from all the reading and some "studies" that I've read it's down to change your oil and filter every 3K and you're set (for normal driving).
