Left rear chirping noise
Old 03-16-2011, 08:19 AM
Why me??
mikedog4's Avatar
Ok this is driving me crazy. I have a chirping noise from left rear brake/wheel area. It only occurs at low speed <10 and usually after being driven for 20+ mins. It is rotational. I have pulled the rear brakes apart 2 times. First time I sanded/molykoted the pads in December. Last saturday I turned the rotors, grinded the rust off (and painted them), chamfered the edges on the pads, sanded and molykoted again, bent dust shield away from rotors, reinstalled. Drove chirp free for 3 days and its back this morning. Any thoughts? Have I missed something? The pads are OE w/ 5.1mm left.
Old 03-16-2011, 09:03 PM
LoveMyTL-S's Avatar
What did this guy miss?
Old 03-16-2011, 09:57 PM
Turbonut's Avatar
If you drive with light pressure on the brake pedal does it stop, how about if the e brake is pulled on slightly when moving, does it stop?
Old 03-17-2011, 08:01 AM
Why me??
mikedog4's Avatar
It does stop when the brakes are applied. I have not tried the ebrake
Old 03-17-2011, 02:18 PM
Turbonut's Avatar
If light brake application stops the noise, try coating anti-squeal lube on the back of the pads.
Old 03-17-2011, 02:47 PM
Why me??
mikedog4's Avatar
I have coated the shims in the anti-squeal lube both times. I think it may be a hub or parking brake issue at this point
02-25-2020 09:57 AM
PortlandRL
09-14-2015 12:01 PM
Ny1718
09-11-2015 09:21 AM
jliu6789
09-08-2015 08:02 PM
Quick Reply: Left rear chirping noise
