Knocking or ticking noise from engine at idle
mine does the same. weird, slight knock during idle. (05 TL A-spec)
+2
but I think its just supose to be like that because of wear and tear?? |
wow... just as a tip don't move around so much so fast... I'm feeling pretty dizzy...
From the crappy youtube converters that dulled the sounds, it appears that your belt tensioner has become a bit noisy. Have them check and replace it. |
Meh, with 7,500miles i wouldnt know how it would get lose. lol sorry if i got u sick.
Quote:
since the video was removed, i can not verify what it is HOWEVER.. have u checked how much oil u have in the car? It may be that you are low on oil.
I used 91 a couple of times, but ever since 2 months ago, i used 93 v-power, sometimes 93 mobile. And i even reset the car the way to you told me. Here is the vid
http://www.youtube.com/watch?v=lXSW2VhG6AA
Sounds like a normal VTEC to me.
VTEC = Valves Tick Engine Clicks |
Mine sounds like that too.
Quote:
Any other symptoms? CEL? How's your mpg?.. What's that noise right after you're accelerating.. it sounds wishy-washy.. I can't tell if its background noise / turn signal / or related to the sound you're describing. I'd check for any leaks through the intake and exhaust gaskets..
The windows creaked open, and i avg 15mpg, city but when i drive under 50, i get 17.
Quote:
:whyme: |
My car is making the exact same noise. Seems like its coming from the pulleys and from the top of the engine.Honda mechanic said he didnt hear anythinng unusual???It only makes that noise when the car is idling kinda driving me crazy, if anyone finds the cause please be sure to post.Thanks.
07 tl-52000 mi |
Have the same worrying issue. Changed the timing belt, water pump, belt tensioner and still!
rod- did figure out what it was? mine is knocking now . 05 w/ 114k
my 2000 acura 3.2 tl has 219,000 on it ticks but still shit and gets if any one finds out what is causing that damn tick please let me know
ticking sound!
hi I got the ticking noise when the car starts and warms up it starts. also when i press the gas pedal and sometimes it disappears when i press it again, and tell also it speeds up with the rpm's. i have a video but not sure how to upload it. any thoughts.
thanks. I looked under the steering wheel next to the pedals, inside the hood the firewall its somewhere coming from their but cant pin point it. the vehicle is a 2000 acura tl 164k miles. |
Check your plugs make sure they're all torqued down, esp #5 (front center, by radiator).
did check the plugs and double checked if they are good and tight. But ts not coming from the engine. Its coming somewhere between the gas pedal cable that goes through the wall from the inside to the engine(throttle body). Is their a way i can post video!
Alright folks I have found and took care of that annoying sound. I was coming from the Vapor Canister Purge valve. Replaced it and the noise gone.
2008 TL Knocking Noise
Hello fellow TL owners! This is my first post on the forum and hoping to get some help. My 2008 TL has 98K miles on it and has knocking noise coming from the engine for the last 4-5 weeks. It syncs with engine revs. Please see the linked video and advise if this is something serious. It's a 3.2L 2008 TL.
A lot of them sound like that - several other threads here about it. I'm not sure what the cause of it is or how serious it is, but I think a lot of them have been making that noise for quite some time.
One thing you could try it this: Easy Fix for Honda Engine Noise - ALLDATA |
valve adjustment
check the tensioner for the timing belt and the accessory belt.
Inside engine
Sounds like your lifters are not getting lubrication. So it's definitely inside the engine. Not external.
Hey good morning all, I have a 2004 Acura Tl 3.2 and I am having a similar issue. When I start the car it sounds like a rumble coming from the engine and I can almost feel it while my foot is on the brake pedal. When I put the car in drive and take off slowly I can hear it rattle a little bit more. At low speeds (taking off) it does it a lot, but on the highway it seems like it drive fine.
Any ideas? |
While standing outside when the car is idling can you hear anything? and if so the location where it sounds like it's coming from?
Seems like this is getting more common as the car ages with all Tls? Anyone have an update on this issue? Like most of the members said noise is coming from the passenger side of the engine and is more apparent when under the starter and ac condensor area?
Tapping sound?
Quote:
Ticking knocking noise at idle from engine.
Hi so I sold the vehicle some time ago, but what I remember, I had the car in idle and found the solenoid for the vapor canister purge valve causing the noise, it's all one piece. Should be located back, right side engine.
| All times are GMT -5. The time now is 08:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
