Knocking front end-'05 TL
A lot of things can cause a front end clunk. Ball joints, motor/transmission mounts, lca bushings, end links, sway bar bushings, subframe mounts, rack bushings... There's a great video by ericthecarguy showing how to locate a suspension noise. I think motor mounts would be very likely.
OK if the car does not vibrate when going down the road you can rule out ball joints. When the ball joints go bad you will always have some wandering and vibrations.
If the noise is only when going over bumps, then you can do you sway bar bushings and endlinks
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
