Keyless Memory Settings & Homelink
Old May 21, 2010 | 07:53 PM
josemartinez's Avatar
Hello Everyone
I Just bought my Acura TL 2004 two months ago, and I have two question about configuration:
1. I need to acces to the Keyless Memory Settings, but I got the error that customizing is not available because the remote is not linked. I pressed the lock & unlock button at the same time on the remote but nothing happens, the led didn't blink. I want to know if I'm missing something or the problem is my remote (all the buttons work fine).
2. I programmed one button of the homelink to open my garage door, but when I tried to program a second button I reseted the configuration (pressing and hold the first and the third button) instead of programming the second button directly. Now the memory is clear, and I tried to program my first door again (pressing and hold the one of the homelink button and the garage remote button at the same time, just like I did the first time), and the homelink isn't learning the code now; so again, I want to know if I'm missing something.
I tried to do those things with the 4 doors closed and the switch in on. It would be great if anyone can help me in any of both cases.
José
Old May 22, 2010 | 01:38 AM
Will Y.'s Avatar
Registered but harmless
1. Press and hold the lock & unlock buttons until the LED blinks-- should be several seconds-- to link each remote fob.
2. When you pressed the first and third button to clear the system, did you do so per the manual to completely clear all the Homelink settings? Try doing a complete clear/erase before setting up the Homelink for the garage door.
The other possibility is that the garage door is a rolling code system, and the procedure stated in the manual for linking is slightly off, IIRC.
Were you able to open the garage door the first time you programmed the Homelink?
Welcome to AZ.
Old May 22, 2010 | 08:56 AM
Hello Will, thanks for your quick reply and your welcome.
1. I did, even for 1 minute and the led didn't blink. I have 1 remote with a flip key integrated that I bought in ebay, I guess that it couldn't link because is not original; I have the other remote that came when I bought the car, but I'm not sure if it's OEM because the letters on the back are erased. Maybe only OEM fobs can be linked, and the one that came with the car is not original, that is what I thought.
2. The manual said to press the first and third button to clear the memory when you are configuring for the first time. I did and linked one button and it works fine, I used to open my garage door for one day, and then when I tried to configure the second garage door I forgot and erased the memory again, and now I can't configure it again for none of both doors.
Old May 22, 2010 | 10:02 AM
Will Y.'s Avatar
1) Do you know if the remotes are "driver 1" and/or "driver 2"?
If yes, set the seat and mirror positions with the DPMS using the appropriate door button, then try to link the appropriate remote again. Linking should occur within ten seconds of holding the buttons.
If that does not work, you may need to program the remote(s) per this thread: https://acurazine.com/forums/3g-tl-2004-2008-93/programming-remote-transmitter-keyfob-3g-garage-l-079-a-556315/.
The flip key is OEM for the '07+ TL and had to be modified to work on the '04.
2) Clear the Homelink memory completely again, then immediately start the linking process with the first door garage remote.
If that doesn't work, check out I-049 in thread https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/.
Old Apr 14, 2015 | 08:58 AM
moreace's Avatar
Anthracite Trend Setter
Bump. So I am not in this same situation. Seemed fine, then all of a sudden not.
My key fob still works. Will lock, unlock, trunk etc.
Tried holding the lock and unlock together multiple times, no change.
Tried the direction to "re-link" the keyfob about 12 times. No change.
Still says on the MID that I can't change setting as the key fob is not linked. What I need to do is program the locks to lock and unlock when shifted to drive/ park. Unlock all 4 doors at once when unlock is pressed...
Any ideas?
Old Jun 30, 2015 | 12:24 AM
David_BNSF's Avatar
2005 TL
I'm dealing with the same issues. I hold both buttons until it blinks once and still get the same message "customizing not available until linked to remote". I'm fresh out of ideas. Anybody with any input?
Old Sep 21, 2018 | 11:17 AM
Slpr04UA6's Avatar
-------Tim-------
I’m getting the same message “cannot change any settings, due to remote not being linked”. Haven’t tried the holding of unlock/lock buttons, but will. I am using a switchblade key, has worked for reverything fine. I just noticed the doors not locking once put in drive, and wanted to get that feature back. I did replace the car’s battery a few months back.
Old Sep 22, 2018 | 11:46 AM
GhostTL09's Avatar
link the remote Slrp
Old Sep 23, 2018 | 02:52 PM
Slpr04UA6's Avatar
-------Tim-------
It worked! Finally!
Just had to link the remote. Weird, but whatever....
Old Jun 5, 2020 | 05:08 AM
Sergio Alfaro's Avatar
5th Gear
Same
Originally Posted by josemartinez
Hello Everyone
Did you ever get this resolved? Same thing happening to me
scatterbrain
2G RDX Problems & Fixes
23
Apr 23, 2015 03:32 PM
billinohio
Mar 26, 2007 11:55 PM
Pro Stock John
Nov 21, 2005 10:50 AM
zerovandez
Aug 6, 2004 10:05 PM
daverman
Oct 11, 2001 07:17 PM
