Key Fix
Old Jan 26, 2011 | 08:39 AM
VGT's Avatar
VGT
Key Fix
Hello! Probably a simple question, but does anyone else's key look like this?
Any easy way to fix it short of buying a new key?
Thanks!
Old Jan 26, 2011 | 08:43 AM
CLtotheTL32's Avatar
I've seen a few like that and I've also seen a few where the key is fully inside of the fob. I would just keep it
Old Jan 26, 2011 | 12:39 PM
LasVegasTL's Avatar
Originally Posted by cltothetl32
i've seen a few like that and i've also seen a few where the key is fully inside of the fob. I would just keep it
+1
Old Jan 26, 2011 | 12:43 PM
Ruby's Avatar
US Navy Seabees
mine doesn't stick out that far if I push it all the way in. I don't know of any way to fix it however. Good luck
Old Jan 26, 2011 | 01:38 PM
stvtec's Avatar
'06 WDP TL 6MT
Old Jan 26, 2011 | 03:39 PM
Old Jan 26, 2011 | 06:11 PM
guitarplayer16's Avatar
On my key, you can't even make out which button is which since all the labels are worn off.
Old Jan 26, 2011 | 07:02 PM
csmeance's Avatar
Acura has a TSB on this, I got 2 new keys for my MDX out of it!
Old Jan 26, 2011 | 11:54 PM
jimmyl's Avatar
Plastic schmastic
Originally Posted by stvtec
Ya made me laugh Jersey!!
Old Jan 27, 2011 | 07:04 AM
VGT's Avatar
VGT
Do you have a copy of the TSB? Or is there a place here to find it?
Old Jan 27, 2011 | 10:36 AM
csmeance's Avatar
3G garage, TSB sections:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
it's 10-008
Old Jan 27, 2011 | 03:37 PM
gcxandrew's Avatar
https://acurazine.com/forums/showthread.php?t=613659
it's 10-008
the link doesnt work anymore
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Old Jan 27, 2011 | 04:32 PM
Will Y.'s Avatar
Registered but harmless
Yes it does, if you follow Ron's instructions at the top of that post:
Originally Posted by RonA
We have regained our access. Follow these instructions.
1. Open this link[url omitted in this quote].
2. Select the entries as follows:
Acura
2010
TL
Then click on "submit vehicle information"
3. Open any one of the listings.
4. You can now open the below listed links.
You click on the TSB link AFTER steps 1-3.
Old Feb 5, 2011 | 07:58 AM
Speedieguy's Avatar
Has anyone tried some type of DYI fix on this? Would it hurt the key to take it apart and try?
Old Feb 5, 2011 | 08:50 PM
meburdick's Avatar
'17 RDX Tech AWD - WDP
If you're referring to the key poking out of the FOB (as opposed to the wear on the buttons), it's warranteed. I took my Driver 1 FOB for my MDX to the dealer when it was popped out like that, and they replaced it under warranty.
FWIW: Those switchblade keys are HORRID. I remember when everyone was soooooo excited that they were coming out. People were going out and buying them, then cutting up their keys and "cold welding" them to the switchblade base.
I would take the old style of a fixed-mast key with a separate FOB transmitter any day.
Old Feb 6, 2011 | 02:11 AM
csmeance's Avatar
The keys I sold and Mr. Heeltoe sell are not cold welded, but actually the TL-S key milled and cut with a CNC machine to make the grooves so it's still the OEM key blank.
SidhuSaaB
May 30, 2020 12:40 AM
eastcoastguy
Oct 29, 2015 03:00 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
kixo
Sep 25, 2015 03:07 PM
