Just Removed Moonroof Visor... WTF!
So I decided to remove the moonroof visor and found that it marked and scratched the shit out of my roof. Any idea if I can get this cleared/fixed or should I just go with vinyl wrapping instead?
justnspace (05-30-2017)
I have yanked these damn things off all my vehicles now except 1 where damage was bad and needed it covered.
Deja Vu here big time. Just went through this on few of my cars some worse than others and detailing will not remove these unless you are using aggressive products and/or wet sanding, the damage is too deep in the clear. Well it didnt work on mine hopefully you'll have better luck.
Mine had the sunroof visor when I got it. Same issue as yours. I will tell you from my experience, polishing alone WILL NOT remove all the scratches.
Years of dirt and dust got caught under that rubber and whenever that visor shifted a bit, it was essentially a nice sandpaper effect on the paint. The visor sucks anyways, it was causing a whistling noise at highway speeds.
What is probably required is wet sanding. My scratches are fairly deep as well. 100% correction is, unfortunately, out of the question.
I have some other spots on the car that require wet sanding, so I want to tackle them all at the same time. I will probably do all of it when I am also doing touch-up paint work, to save time.
If you want to tackle the job yourself, first try polishing it, machine will be best. Then step up to a heavy cut compound. If you still aren't happy, move on to wet sanding, but be VERY CAREFUL! I would highly recommend a sanding block so you can apply even pressure throughout the sand paper. I would start with 3000 grit or higher and step down to a 2k at the lowest.
With any form of paint correction, you want to start least aggressive first! Continue to step up the "intensity" until you are getting results you are happy with. Just be careful with the wet sanding because you can go through the clear coat if you are not careful.
