Interior squeak by shifter
Old Mar 14, 2013 | 11:57 AM
cehak's Avatar
6th Gear
I posted about this previously... but the fix that I tried, I had no luck with. Basically, I am having a lot of squeaks and creaks from this general area.
I tried removing this piece and putting some foam-type material underneath. The noise has reduced, but it still there and still just as loud and obnoxious. When i remove this piece the noise will go away (somewhat) but it still faintly there.
It is extremely annoying...
Any help?
Old Mar 14, 2013 | 11:58 AM
cehak's Avatar
6th Gear
there are links integrated into the text (I had figured that it would change color) *'this general area' 'this piece'*
Old Mar 14, 2013 | 12:15 PM
Will Y.'s Avatar
Registered but harmless
Others have put a single layer of Teflon tape around the console edges covered by the bezel plate to stop the squeaking, IIRC-- check the 3G TL Service Dept/Garage thread (https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/) stickied on the main page of this 3G TL forum for the various interior rattle threads.
Welcome to AZ.
Old Mar 14, 2013 | 01:14 PM
cehak's Avatar
6th Gear
I'm sorry... could you be more descriptive "console edges?" like if I were to remove the plate, the edges there down in to my shifter workings? I rarely do any tweaking to cars so I have no clue. I am reading through the threads that you sent me though in the "garage"
Old Mar 14, 2013 | 03:18 PM
Will Y.'s Avatar
Right-- the edges of the console cutout for the shifter-- basically the area right under the bezel plate.
I think the Teflon tape may permit the plate to move slightly without as much friction from the console, thereby lessening any noise.
Jul 16, 2017 07:33 AM
Jimmy_D
Oct 7, 2015 11:52 PM
MikeJM310
Sep 24, 2015 07:24 PM
