Interior Lights Problem!!!
Old Aug 27, 2006 | 02:01 AM
Aznpersuasion's Avatar
Supercharged 2005 TL NBP
Ok, well i'm having problems with my interior lights of my car.. the HFL and lights on the steering wheel won't come on.. the dash lights where the gauges lights won't come on.. my seat warmer's lights won't come on either.. any suggestions on what I should do to get them fixed? Would it be because of my cold air intake? I never had these problems till I installed my intake...
Old Aug 27, 2006 | 10:26 AM
csmeance's Avatar
did you reverse the ternimals on the battery when you put it back? you might have blown a fuse, or might have knock one loose. In the engine compartment, next to the air box, there is a fuse box, make sure that the fuses are seated properly.
Old Aug 27, 2006 | 11:03 AM
DCC's Avatar
DCC
Sounds like a disloged or burnt fuse like csmeance said. Check out both fuse boxes while you're at it. It's odd that all those lights burnt out at once...so usually that's a fuse of some sort. report back to us so we know what you found out...
Old Aug 29, 2006 | 05:21 PM
Well I had it checked out the other day and well the dealership told me that the lights blew out for some reason.. I have no idea how that happened but that's what they said so they ordered new parts so they could install it, later....
~Jason
Old Aug 29, 2006 | 05:22 PM
Oh the fuse box was all fine.. just the lights that's behind the steering wheel was all blown..
~Jason
Old Oct 26, 2006 | 05:14 PM
Precision Crafted's Avatar
OK, here is my problem.
The light for the sunroof switch light up anymore, the Send/Talk buttons don't light up, and now the trunk open light doesn't light up.
If I had blown a fuse wouldn't surrounding lights be effected.
It is the oddest thing.
If anyone has ideas, thanks!
Old Oct 30, 2006 | 12:49 PM
Tripnbeats's Avatar
Yea the lights in my wheel controls for the radio and in the seated heat button are blown for the drivers seat.....i havent noticed any other ones blown
Old Oct 30, 2006 | 03:10 PM
Do you know what caused your problem? Did you ever have to jump your battery? I ask because before buying a new battery I would have to have jumps because the Navi would drain too much power when I would go to the drive-in.
Old Oct 31, 2006 | 10:47 AM
Tripnbeats's Avatar
I had to jump the car a feww times b4 they replaced the battery for me........ thing is I didnt notice the problems until after I installed my strobes but when I installed them i didnt disconnect anything but the tail lights.... Im sure they tell us to disconnect the battery everytime b4 performing work for a reason LOL!!! I just ordered the bulbs they cost me like 9 bucks.... im still waiting for that and my motor mount. let me know if u hear anything more on that
Old Oct 31, 2006 | 02:30 PM
The total amount is 9 bucks then that isn't too bad. Also, are you doing the install yourself?
If I hear or read anything else on the matte I'll let you know. It kind'a burns me though that any interior light minus the "dome" light had burned out on a car that is not even 5 years old.
Old Oct 31, 2006 | 11:59 PM
Tripnbeats's Avatar
nope doing it myself takes 20 mins ive ripped apart so many of these cars i can do it with my eyes closed
Old Nov 1, 2006 | 02:28 PM
Nice!
Old Jan 18, 2007 | 06:24 PM
quanTL's Avatar
all my buttons and switches light up except for the MIRROR switch l-r button and the heated mirror button.
Old Jan 22, 2007 | 09:23 PM
tylerr1's Avatar
I have the same issue. The lights behind my volume and channel buttons on my steering wheel were out along with the light behind the driver's side seat heater. I went to the dealer and had them replaced today ($75 with labor.) On the way home I noticed the light behind the heater mirror button, the VSA button, and the "Enter/Reset" button near the HID are also not working. Any ideas from anyone what may be causing this?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
