Installed Tein SS now vibration under accel
13.2@ 107 on Street tires
So i lowered the car..not slammed all the way...and now when i give more than 50% gas in 1-3 a vibration goes through the chassis...feels like something is off balance but i have no clue what it could be..i thought it was teh alignment but then i got it aligned and it still does it...could it be from just the tires with the camber? let me know what you think
The minimum drop on teins is 1.5 inches and normal max is 2.5
If you went over 2.0 you need camber kit for sure in the rear and the
fronts depending on your rim size
Recheck everything for tightness after it has weight on it
The alignment shop should have been able to see if anything looked out of place
What does the alignment spec sheet say for results?
BoricuaTL
Apr 8, 2016 01:08 PM
nanos
Nov 12, 2015 08:41 PM
