Improve Acceleration
Old Apr 17, 2008 | 03:52 PM
SILKO's Avatar
Hey Guys
I have had my '05 TL AT for over a year now and the performance is good but not consistent...it has its moments.
There are times when the car will hesitate before it actually accelerates when i step on the throttle (2 seconds later, I will get a burst)...I want my car to have good acceleration from jump ALL THE TIME...
Have any of you faced this issue? How can I fix it without adding something to my car that won't make it loud and obtrusive? (I hate those guys with the mods that make their cars unbearably loud)
Thanks alot
Old Apr 17, 2008 | 04:43 PM
01tl4tl's Avatar
is it engine lag or transmission lag
Have you seafoamed the intake and cleaned the throttle plate How are the plugs reading?
Do you run Tier 1 gas and 91 octane all the time?
Old Apr 17, 2008 | 05:30 PM
08WDP's Avatar
its the computer lag, say you in 5th gear at 60 and all of a sudden you want all of those 286hp (type S) out of the car, the car cannot offer you that much power/tqr in 5th gear, so it needs to think and say..puts you to 3th then bam! the power comes in and thats when u get that burst, i wouldn't say 2 second, but for a second sometimes it happens.
Old Apr 17, 2008 | 05:32 PM
SILKO's Avatar
not sure! I haven't checked those things out...guess I will go to a local dealership to check it out...cause I get the worst help from the Acura dealerships in the NY area
Old Apr 17, 2008 | 05:35 PM
SILKO's Avatar
how do I fix this computer lag, O8WDP?
Old Apr 17, 2008 | 08:27 PM
timmahh's Avatar
it's me, Alan Rickman.
smart ass answer?
Upgrade your memory; defrag the system.. possibly a new processor...
heeeh
Seriously though.. the car doesn't take that long to perform calculations; however in the interest of fuel economy it might be waiting to see what your plans are; ie - are you going to shove the pedal down further, or did you just need to accelerate a little.. ?
Old Apr 17, 2008 | 08:49 PM
emas's Avatar
I just tried AmsOil Performance Improver gas additive in my wife's car that was having similar problems, and have been fairly please with the results.
Old Apr 17, 2008 | 10:48 PM
csmeance's Avatar
put some seafoam in the tank to aid performance as it will clean up the motor and any comtaminants in the tank. Also unplug the battery for about 30 minutes and perform an Idle relearn procedure, and you are good. This will reset the ECU. Also there is another way to do this, by putting the car into Position 2 and hold down the gas pedal for 30 seconds, then turn on the car.
Old Apr 18, 2008 | 08:38 AM
SILKO's Avatar
what is Position 2???
how often would I have to put seafoam into the tank, and how much should I put at one time????
Old Apr 18, 2008 | 11:09 AM
keunho's Avatar
Is there any mod to fix this problem?
Old May 16, 2009 | 01:43 AM
Phambam12's Avatar
Phmbm12
take out your resonator lol
or put a CAI on it
Old May 16, 2009 | 07:36 AM
blkaspec's Avatar
Full of water...
He is talking about your key position, turn it to the II position, i think it is labeled, and then follow the instructions described above.
Old May 16, 2009 | 10:49 AM
BukvaMan's Avatar
get a sprint booster for 300 $. supposedly it should cut DriveByWire delay in half. Excelerate is giving a week to try it and if not to send it back for a refund. Im thinking to give it a try... i hate the delay myself.
Old May 16, 2009 | 10:56 AM
Gary TL S's Avatar
JDM ... NOT !
^^ yup thats what I was going to say. I have sprint booster and beleive me thats all you need to fix your problem !
Old May 18, 2009 | 12:09 AM
bbktl's Avatar
For the position 2 procedure do you turn the engine on after 30 sec while your gas peddle is pushed to the floor?
When do you let go of the gas pedal?
Does that restart the ecu?
Old May 18, 2009 | 06:25 AM
ridenfish39's Avatar
.........get a 6-speed
Old May 18, 2009 | 12:12 PM
Majofo's Avatar
engine lag - TBW or fuel injectors..
trans lag - You might as well take it behind the barn and pump it with led. If you're lucky.. you do a 3x3 with Z1 and it doesn't take a dump on you.
Definitely seafoam at both ends.. how many miles??.. you may need new plugs (NGK Iridiums) as suggested.
sprint booster.. short answer.. Not for your problem.. don't spend $300 thinking it will 'fix' your issue.
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
