Impossible TL Type-S Misfire
Old 09-04-2018, 09:36 PM
  #81
Chris Jordan's Avatar
Is this normal number 1 has a white jacket on it all others black
Old 09-04-2018, 09:39 PM
  #82
Latent car nut
horseshoez's Avatar
Received 2,019 Likes on 1,416 Posts
Cool, keep us posted.
Old 09-04-2018, 09:50 PM
  #83
Nothing wrong with Delphi eh , been around for long time
Old 09-04-2018, 11:28 PM
  #84
K in a nut shell is wow this thing rips , what the he'll is in those plugs , I bit improvement in deed .
Now for the downer , still nothing changes with the idle to 1500 ish rough with lite throttle .
Ya all still thing it's the coils eh ? Oh by the way cycling threw with the new coil did nothing .
My cost the the new coils is very good . 🤔🤔
Anyone check out the two pics I sent previously one was the coil wire and socket and one was the brand of coil pack .
Happy to say all that work was worth it , but still frustrated With this missfires
Old 09-05-2018, 12:00 AM
  #85
Holly shit !! That's not cheap .
I have a parts store here in town OEM replacement $50.00 ea
Old 09-05-2018, 05:27 AM
  #86
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
I'll never understand why people will cheap out on plugs for something that lasts 105K+ miles. Retail, the NGK plugs run for $60. They can be found on sale for less than $50. They cost less than $8/year for the average driver...
OP, you never did answer: what analyzer did you use?
Has the car run like this since you acquired it? Where did you purchase it?
Honestly, at this point, it's probably worth paying a dealer $125 for a diagnosis...
Old 09-05-2018, 07:53 AM
  #87
fair enough , well she has brand new ngk plugs and all I can say is WOW! A huge improvement. But the throttle just off idle is still there . This morning when she was could it was quite apparent that she started up roughly.
Old 09-05-2018, 08:22 AM
  #88
I will inquirer about the brand as I am not familiar with it . My Machanic used his snap on brand scanner
Old 09-05-2018, 08:24 AM
  #89
to be honest I really didn't notice it to much when I first looked at it , the car is in quite clean shape , bought it of a Machanic works for GMC out of Burnaby here in town .
Figured it needed a tune up , clearly it did . Proof being with the new ngk plugs
Old 09-05-2018, 10:54 AM
  #90
nfnsquared's Avatar
Wait, I thought you "cheaped out" and added the Bosch plugs yourself? So you yourself created the need for a "tune up"....
Old 09-05-2018, 11:16 AM
  #91
Be for I added the bocsh plugs it needed new ones yes , I didn't put in the ngk to start , my bad .
They are in as or last night
Old 09-05-2018, 09:19 PM
  #92
So over the past couple days the tighten fuel warning light keeps coming on , does this have anything to do with the rough throttle
Old 09-06-2018, 02:49 AM
  #93
Latent car nut
horseshoez's Avatar
Doubt it, but it does mean a new purge valve is in your future.
Old 09-06-2018, 09:38 PM
  #94
Did anyone catch the pic I posted on the coil pack wire on cylinder 1 ?
Today's update , installed new PCV vavle and new EGR valve.
Nothing changed , the evap should be in on Monday /Tuesday I also gave in and ordered all new coilpacks . Fingers crossed 🙈
Old 09-06-2018, 09:54 PM
  #95
nfnsquared's Avatar
All the time and effort and expense of parts that you've expended so far could have been minimized by a $125 dealer diagnosis....
Have you tried calling the mechanic that you bought it from to ask him about the problem and/or the harness?
Old 09-07-2018, 08:50 AM
  #96
i did and as typically , he's knows nothing . Will call the dealer today and set up apt for new weekend, to solve this once and for all 👍.
Think throwing new coils in , good idea ?
Old 09-13-2018, 10:08 PM
  #97
Update on my tl
k all
So I took my tl into the dealership and had them take a look at it . Said as per there scan , all is running inside of acra peramiters. But did say that they that there was indeed miss fires present.
Made the suggestion to replace the coil packs
Get timing belt done
If miss fire is still present then replace injectors, knock sensor, APP sensor.
Said that the AF sensor could be contributing to it too.
I really need some direction here guys . This is starting to be not funny any morany
​​​​​​is it possible for an AF sensor to be acting up causing these symptoms .
Cheers
Old 09-13-2018, 10:10 PM
  #98
Update
Did the coil packs today , nothing changed what so ever .
Picked up new AF sensor today , thinking of trying it on bank 1 and 2 see if ones on the way out and if that doesn't help things
Old 09-14-2018, 06:04 AM
  #99
nfnsquared's Avatar
Why in the world did you spend a fortune on coil packs when you've already proven it wasn't a coil pack?
Post the diagnosis sheet that the dealer gave you...
Old 09-14-2018, 06:14 AM
  #100
teh CL's Avatar
Old 09-14-2018, 07:12 AM
  #101
what have I done to prove it wasn't the coil packs
The dealership said that's were they would start with replacement of the coil packs , and if that did not solve anything than to continue with items that I listed
Yes will do
Old 09-14-2018, 07:14 AM
  #102
Originally Posted by teh CL
I actually got then at cost plus 10% so it wasn't that bad
Old 09-14-2018, 04:51 PM
  #103
nfnsquared's Avatar
Yes will do
You bought one new coil pack and rotated it through all 6 cylinders and that didn't change anything, correct?
What did the dealer say about the "fuel cap" message? This was an Acura dealer, correct?
Old 09-14-2018, 07:36 PM
  #104
Yes that is correct , but the dealership said to change all of then either way , due to the fact that one or more could be acting up under load ..
The fuel cap message has disappeared, that was on and off for a couple days then gone .
I will post now the reports from acura to view
Ty
Old 09-14-2018, 07:41 PM
  #105
Old 09-14-2018, 07:45 PM
  #106
Here is one more of the reports
Old 09-14-2018, 09:31 PM
  #107
What it this guys
Ty
What has some one done here , is this part of the audio system ?
Old 09-14-2018, 10:44 PM
  #108
nfnsquared's Avatar
Where is their written analysis?
Again, what dealer was this?
If that is the passenger right kick panel, that's the amp.
Old 09-14-2018, 10:46 PM
  #109
I sent too print outs of the report earlier
Yes passengers kick panel ok so stereo the eh . Any idea what the heck they were up too
Old 09-14-2018, 10:47 PM
  #110
Sorry the dealership was Loughed acura in coquitlam
Old 09-14-2018, 10:50 PM
  #111
nfnsquared's Avatar
All I see is a bunch of numbers, I don't see any analysis/conclusion/recommendation...
Old 09-14-2018, 11:06 PM
  #112
The numbers are there scans
And as far as recommended services I did list those previously
I can take a picture and post here shortly if ness
Old 09-16-2018, 12:53 PM
  #113
MyGuti's Avatar
your tighten fuel cap msg is normal, can be easily fixed for 40 CAD, and that's the amplifier for the stock radio system. Not sure why they would need to access that area for diagnostic testing (not sure what other wiring is in that area). Also, that print out of their testing doesn't say anything about their findings, you might be better off getting an explanation from them. Unless there is a member on here who can decode those
Old 09-16-2018, 09:57 PM
  #114
that's what I was hopping, if someone knew what there reports said . But then again if everything falls within there perimeters then it all would look normal right .
I showed my brother tonight at dinner and he said well we now know that u have miss fires on cylinder 5 and 6 so work with that . He thinks possibly injectors?
Said buy two new ones and see what it does .
Old 09-23-2018, 11:59 PM
  #115
Cold Business
SocomM4's Avatar
Clean throttle body?
Old 09-25-2018, 11:41 PM
  #116
Update on my type s
So took it in to a performance tuning shop today and had them preform a full leak down test and scan
ResultS are that the intake ,exhaust and coolant and solid .
the pistons on the other hand are said to be some what not good .
Now my problem has been from day one miss fire on cylinder 5and 6 no know cause what so ever to date .
Ironically both cylinder 5 and 6 are above the passable allowable limits for the test . Meaning they would not hold the compressed air , all others are within limits .
Now my question is is this even possible that these two cylinders are actually causing my issues ??
What I can't understand is I did a compression test and got great numbers , absolutely not blow by ie burning oil , and get Greta gas mileage.
It just doesn't add up for me .
Shop says just drive it , it runs strong minus the above
Old 09-25-2018, 11:43 PM
  #117
yup first thing we did , practicality free lol
Old 09-27-2018, 04:22 PM
  #118
nfnsquared's Avatar
Update on my type s
"The pistons on the other hand are said to be some what not good.."
In what way?
Sounds like bent valves causing the leak to me, probably from an over rev. And that would really suck, because if it was over revved by the previous owner, he certainly was aware when it happened...
You're going to have to pull the bank 2 head to know for sure....
Old 09-27-2018, 08:50 PM
  #119
In what way?
as I mentioned my car went in for a leak down test witch will indicate, a bent valve ie not seating right.
the summary is . The top end is sound ( intake and exhaust ).
Coolant is sound ie head gasket is good .
the test on the cylinders found that 1,2,3,4 are all with in limits . 5and 6 are slightly over the limits when it come to blow by the piston rings , ie air could be heard coming out of the oil cap.
My question is, with that information would this cause my miss fires ?
Old 09-27-2018, 09:10 PM
  #120
Latent car nut
horseshoez's Avatar
Nope, engine sounds reasonably solid.
