Idling very rough
Old Oct 18, 2012 | 07:17 AM
TLFTW's Avatar
Idling very rough
Hey guys I have 2004 TL with 123xxx miles. It has been running well. Recently the CEL light has come on with misfiring codes for all cylinders plus a random misfire. I went ahead and changed spark plugs and found a bad coil pack. The 105k job has also been done at 98k and car has been perfectly fine. I am still getting the codes. I also notice the car only misfires at idle and operating temperature. Any idea what it could be?
Old Oct 18, 2012 | 12:00 PM
Will Y.'s Avatar
Registered but harmless
1) Get the codes read for free at an auto parts store or by someone with a OBD II code reader and report the code to us.
If the code readings aren't obvious, you can then do a search for the codes here on AZ or on the web generally to get an idea which part(s) may be involved.
2) My guess, without any code, is that it may be the EGR valve. Let me know if I'm right or wrong.
G/L.
Old Oct 18, 2012 | 10:32 PM
Be-in my TL's Avatar
06 WDP / 07 WDP Type-S
You can check for a vacuum leak with brake clean, spray around intake. If you hear the engine review up,it got some brake clean into the cylinder. All cylinders misfire, think about what could cause all cylinders to misfire. Won't be six plugs or six coils.
Rev up. Stupid autocorrect
Old Oct 19, 2012 | 07:10 AM
TLFTW's Avatar
G/L.
I had the codes read but I just don't remember exact numbers. But they are codes for what I mentioned above
I will try that. Thanks
Old Oct 19, 2012 | 11:23 AM
Will Y.'s Avatar
I had the codes read but I just don't remember exact numbers. But they are codes for what I mentioned above...
O-I-C.
If the codes were for misfires due to a bad coil pack, then try putting the TL through the "Idle Relearn Procedure" if that was not already done: https://acurazine.com/forums/3g-tl-problems-fixes-114/rough-idle-786866/.
Old Oct 23, 2012 | 12:31 PM
I hate cars's Avatar
Ignition problems are usually worse when hot. Compression problems show up at idle. A stuck open EGR will be worse at idle. If you only have a misfire at idle, check compression first. The only way all 6 cylinders are going to have low compression is if you have a 6mt and overreved it.
baelim
May 10, 2018 09:53 AM
DerrickW
Nov 15, 2015 05:52 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
ceb
ILX
Sep 27, 2015 10:56 AM
