Icons Missing?
Old 12-06-2005, 02:14 AM
tl1
tl1's Avatar
Icons Missing?
When I start my 04 tl and push the "AUTO" button for heat or a/c the the icons (little people with arrows) do not appear. The strip is blank until I push the mode button. Also when I push "DEFROST" only the drivers side comes on. Anyone have a simular problem?
Old 12-06-2005, 08:32 AM
jwclements1's Avatar
those icons aren't supposed to show up in auto or in defrost, only when you want to manually change the mode
Old 12-06-2005, 03:00 PM
18,000mi. 29000km
Actuary's Avatar
lol this thread gave me a good healthy dose of laugh
Old 12-06-2005, 08:26 PM
Registered Offender
ImPo Skyline's Avatar
What Actuary said should fix your problem.
Old 12-06-2005, 08:53 PM
Registered Offender
I just went out and checked mine, It seems to work fine. I did find some interesting information about using your a/c. Anytime your under auto setting with the temperature 86 or below the A/C compressor IS running. It shuts off under the "HI" setting. If you use the A/C Off button you will save some power and gas mileage unless you are trying to get cold air. If you are in Dual mode, either passenger or driver temperature setting set below "HI" will run the compressor unless you press the A/C Off button.
tsx_boy
12-13-2019 08:33 PM
gatrhumpy
19
12-31-2015 04:22 PM
blacktsxwagon
10-27-2015 10:12 PM
dainmezron
10-16-2015 06:56 PM
marinrain
ILX
10-06-2015 12:36 AM
Quick Reply: Icons Missing?
