I need help
I need help
I finally installed switchbacks on my 05 TL signal light and it
went great, but after a little while driving the blinkers stop working. (As in the "amber " stops blinking.) I have the ones
that only blink amber, so when I hit the turn signal it just turns off , I make the turn and white led comes back on . Can someone plz help I installed 50 w 6 ohm resistors in the trunk on both sides
Remove the resistors and test to see if they still blink, if they do, bad resistors. If they don't , bad bulbs. And throw away the resistors and do the turn signal relay mod.
When you decide to go aftermarket, you compromise on reliability. I imagine it is a pain in the *** to shove your hand into the headlights everytime.
The bulb itself maybe faulty, which will be a common occurence due to the lack of heat and that allows non-sealed things like LEDs to rust and fail.
