Hyrdolocked or not?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
I dont know much about a car hydrolocking, but last night through today it was gloomy whacky rain in NY. After dropping my girlfriend off last night and on the way home, before hitting the highway there was a big blockade of water that was about up to the sideskirts of a stock height 5AT. I went through it once on the way to the girlfriend's house and on the way home going through the same way, my car made it through half the puddle, going less than 20mph it suddenly stops. I then turned off the engine and hazard lights on and waited for a friend with a 4runner to push me out. I did try to start up the car but it wouldn't crank, and made a thump sound. I had to get it towed to a parking spot and waited for 6hrs around mid afternoon to try to start it up again and it was a no go as well. I then got it towed to a shop and mechanic tried to jump start it and it was a fail. The mechanic called me a few hours later and said it was the starter, and he will get one in tomorrow and will try to start it up with the new starter. Experts, I need your help because this is a family car and I need to get it up running asap. I have read about it being hydrolocked and might need a new engine depending on damage. Is the mechanic correct on the starter or may it be more than a single starter? Any advice or tips would be greatly appreciated!
![Nervous](https://acurazine.com/forums/images/smilies/nervous.gif)
I was indeed on my way onto the belt, i wasnt payin full attention to the sides though sorry
it was dark and just wanted to get home. SSM TL was me if that's who u saw.
Your mechanic is an idiot and he's going to ruin your engine. Pull the plugs out, crank it over, reinstall the plugs and pray there was no damage done.
The following 3 users liked this post by I hate cars:
AZ Community Team
Received 7,770 Likes
I dont know much about a car hydrolocking, ....
a big blockade of water that was about up to the sideskirts of a stock height 5AT. .... my car made it through half the puddle, going less than 20mph it suddenly stops.
I then turned off the engine and hazard lights on and waited for a friend with a 4runner to push me out. ...
I did try to start up the car but it wouldn't crank, and made a thump sound. I had to get it towed to a parking spot ....
try to start it up again and it was a no go as well. ....
I then got it towed to a shop and mechanic tried to jump start it and it was a fail. ....
will try to start it up with the new starter. ....
[RANT]
First, DO NOT DRIVE THROUGH DEEP WATER!! Half the people on this site have CAI and have read about hydrolocking. So, WTF makes you go, "I can make it" as soon as you see deep water in the road? :wtf:
More money than sense, I guess.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Second, when you do drive through deep water and the car stalls thats the GOOD PART. The part in Blue above: DO THAT and then leave it be.
When you try to restart it, that's the BAD PART.
DO NOT TRY TO RESTART A CAR THAT MAY BE HYDROLOCKED. That's the thing that practically guarantees you're going to FUCK IT UP!!!
It's water in the cylinders that stalls it. It's YOU forcing the car to crank with water in the cyliders that BREAKS RODS and BENDS VALVLES.
Once it stalls in water, you have to go through a process, which starts with removing the spark plugs, cutting fuel to the engine and forcing the water out thorugh the plug holes. You DO NOT try to start the car until you're SURE the water is out of the engine.
You should probably also have a compression check performed to insure everything seats/seals properly.
[/RANT]
OP, hope it works out for you. Maybe it is just the starter.
Please don't take my rant the wrong way. It is directed at others who may read this and learn from your misfortune.
The following 4 users liked this post by Bearcat94:
Thanks for the quick replies! I will take out the plugs and crank it tomorrow to see if it will fire up. IHC, I am praying hard no other damage is done and thanks for the reply! You are a highly respected member to me on this forum and I take your knowledge in this mechanical world any day. @Bearcat, I take a lot of bullshit day and night, your rant was not taken the wrong way, I understand where you are coming from and appreciate the insight. This is my first car and first time being in this situation, heart is still pounding. I do not have a CAI installed and I was testing my luck last night, which I found out the hard way luck is not on my side. I will post back asap when I get to the shop tomorrow to see if my luck has changed sides. Thanks again
Thanks for the quick replies! I will take out the plugs and crank it tomorrow to see if it will fire up. IHC, I am praying hard no other damage is done and thanks for the reply. @Bearcat, I take a lot of bullshit day and night, your rant was not taken the wrong way, I understand where you are coming from and appreciate the insight. This is my first car and first time being in this situation, heart is still pounding. I do not have a CAI installed and I was testing my luck last night, which I found out the hard way luck is not on my side. I will post back asap when I get to the shop tomorrow to see if my luck has changed sides. Thanks again
Being an Acha Bacha in
OP, not to pick on you, personally, so please forgive the mini-rant that follows.
[RANT]
More money than sense, I guess.![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
[/RANT]
OP, hope it works out for you. Maybe it is just the starter.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
[RANT]
[/RANT]
^^This
It took me an hour yesterday to drive home from my friends house which was 2 miles away because there was so much flooding at all the intersections and I had to keep rerouting. Yes I could've went through the water... but there was no way in hell was I about to risk it! I even stopped traffic and became "that asshole" who everyone had to go around cuz I could give two shits .. not going to ruin my engine. I ended up backing up a few times and did it safe as possible ... so that I could take side streets and other means to get around it. Longest 5 miles I have ever driven but wouldn't have it any other way. I have the V2 AEM and wasn't going to hydrolock.
I could've taken the highway but I chose not to ... cuz the maneuverability to reroute would be greatly diminished if you encountered a puddle of that magnitude. Last night's storm was pretty bad in the LI/NY area.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Your mechanic shouldn't be qualified to put air in tires.
Car has started up again but still having some worries! Replaced starter, replaced spark plugs, engine air filter and did an oil change. Engine check like did come on after replacing spark plugs and code was Cylinder 1 Misfire. Replaced cylinder check engine light has not come on and drove home, driving experience seems almost normal but when I come to a red light with foot on the brakes, there is a slight vibration feeling. Does this sound like a problem or is my paranoia getting at me?
AZ Community Team
Something like this: https://acurazine.com/forums/3g-tl-problems-fixes-114/locked-engine-wont-crank-help-826102/
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
zrock87
12-04-2013 10:32 AM
