How to replace steerling wheel volume control switches on a 05 TL?
Has anyone ever replaced the volume control / channel / mode switch in the steering wheel of a 05 TL? My volume control on the steering wheel comes and goes, mainly goes. When I turn the steering wheel my volume goes down, then out and I noticed my channel and mode switches don't work most of the time. I believe the whole switch assembly has a short in it (the volume lower will not click any more).
Step by step pictures or manual instructions would be helpful.
You have to remove the airbag to get to those switches:
https://acurazine.com/forums/3g-tl-problems-fixes-114/heated-seats-light-dont-work-plz-helpp-628348/
You'll need a torx 30 bit to loosen the two airbag screws and they are in there tight because acura puts loctite on the screws.
scroll down for the pictures.
Also, check the garage, there are service manual scans for airbag removal. BE CAREFULL!!
https://acurazine.com/forums/3g-tl-2004-2008-93/air-bag-removal-replacement-scans-related-scans-3g-garage-f-013-a-612761/
2, from the back
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
