How to remove passenger vent to fix rattle
I'm using wool felt to fix the rattle in the driver side vent as per the TSB. Unfortunately, I can't seem to simply pop out the passenger side vent as the open/close control below seems to be part of the metal trim that goes across the passenger side dash. Anyone have a picture or a diagram or words of advice as to how this is removed?
Originally Posted by vinnier6
everything just pulls out...keep wiggeling and pulling...its set in there by clips that just push back in...
The metal pieces will come out as part of the assembly. In fact, the metal part is part of the rattle problem, once you get it out you will see. Just grab and pull (with the car door open). Mine rattled real bad, but the dealer took care of it by using felt everywhere on it.
Originally Posted by stavebomb
so scarry! i was trying to get mine out today and i couldnt get it. it felt like i was going to break it! Jeff442 were you able to get yours out?
marcelft
Jul 10, 2018 06:17 PM
3GTLOwns
Sep 9, 2015 09:51 PM
