How bad is this??
How bad is this??
i know its not a good pic, but maybe somebody expirenced this or will know how much $$ to fix.
![](https://i29.photobucket.com/albums/c280/supra098/2010-08-09_19-09-16_8121.jpg)
We can't see the extent of the damage.
Take a better picture, showing the crack.
Because the picture is not showing the crack, it just looks like a scuff mark to me.![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
*edit*
How does one help another, when there are no details provided?
So is it leaking? is it causing your brakes to be not as effective?
work with us, so we can work with you.
*edit*
oh ok, ill try to take one later on, i just thought i show this one for now.. the crack is right below the U shaped...um brake line i think thats what it is..
![](https://i29.photobucket.com/albums/c280/supra098/2010-08-08_16-34-00_5511.jpg)
Nothing is leaking... there is a crack in a welded mount that i welded to the sub frame.
Ah shit what happened?
Maybe try angling the camera better and point out the crack in MS Paint...
ouch! Sorry to hear! It looks like the lower control arm is bent and the half steering rack looks to be bent slightly. You going to need a new headlight, bumper, lower passenger foglight and grille! Is this going through insurance?
unfortunatly its not going through insurance..
Is that subframe supposed to be pulled in like that on the right side of the first pic? Looks like that is the rear mount of the lower arm. Front mount of the lower arm is the compliance bushing. That would be another place to look for damage. Not good.
You can always measure the distance from the center of the front wheel to the center of the rear wheel on each side and the difference will be how far back the suspension has been pushed. If you had a good lower arm that could be installed, if it would fit after the accident that would then give you an idea of how much damage is done after taking another measurement. With that weld broken, I’d put it up on a rack and check all the specs to see how much damage was done to the subframe and go from there. With some hydraulic assistance, heat, time and welding, most anything can be fixed.
2004 Acura TL
Damn Joe?? Sorry for all that damage from hitting a sign. Let me know if you need anything. Are you goin to re-use the headlight some how? Pm and let me know.
You need a rack, subframe, and lower control arm at a minimum.
I've been there before. The rack is like glass, any little thing will damage it. Acura does not condone repairing the subframe and will only replace it. The lca should be replaced because it's likely bent and you don't want to chance it having a crack. Also, the compliance bushing is probably damaged. More than likely wheel bearings too.
time for you to pony up about 4K or make an insurance claim.
1. replace front bumper
2. repalce passenger headlight
3. repalce lower control arm
4. replace ENTIRE subframe
5. redo fender
6. replace misc parts on passenger side around the headlight
5. redo fender
I personally don't want them welding new brackets on my subframe or bending them back into place. Once that aluminum is bent chances are the strength is compromised.
Safety? How about aluminum wheel repairs? They do repairs on wheels that are bent and cracked!
No problem with repairing the subframe, if it's done correctly. In fact, if you look at the FSM, it will supply all the dimensions needed when repairing the frame(s). The title is Frame Repair Chart.
Chances are the subframe is going to have to come out of the car for repair to weld anyway. Why not just install a new one instead of taking a chance on the welding/straightening. Once the metal is bent...twice... it's not going to have the same strength as it did before. It may show up as additional NVH or you might not notice it at all. There's always the chance it can alter the crashworthiness of the car. A longshot I know, but why take the chance when we're talking about a relatively small difference in price.
It just seems like whenever repairs like this are done the car is never the same anymore. Replacing the subframe can get it into "like new" condition again.
The frame doesn’t need to come out to be repaired and the above statement is totally untrue as it’s totally dependent upon how and at what temperature the aluminum is heated and the type of equipment used to do the repair.
Just an FYI, BMW, Audi, Jaguar, Lamborghini, etc, actually have and use factory authorized aluminum frame repair centers.
So much for not being able to make repairs on aluminum subframes. Hopefully we're done.
Haha, seemed like this did die! But im ressurecting it because i am less than 24hrs of getting my car back!!
Subframe, Subframe mounts, Wheel bearing, Axle, Strut, Lower arm, Knuckle.......Is what i needed...WOW!!
I'm still unsure as to why you would pay well over $2,000 out of pocket instead of filing a claim.
How fast were you going to hit a curb and a sign?
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
