Hot air from engine getting inside
Old Sep 18, 2009 | 04:04 PM
Andruha88's Avatar
SpeedDemon
Exclamation Hot air from engine getting inside
Well i had aem v 2 installed, and after that when i drive i feel hot air blowing at my legs where the pedals are.
any suggestions? can it because i am low on radiator coolant?
thanx for your help
Old Sep 18, 2009 | 04:21 PM
1fsthatch's Avatar
uhh is the heat on thees absolutely no reason for this to happen
Old Sep 18, 2009 | 04:53 PM
xrvman's Avatar
2008 NBP
Dants no goood maaan
Old Sep 18, 2009 | 06:48 PM
Andruha88's Avatar
SpeedDemon
i should recieve antifreeze fluid next week, but i honestly dont think that its is the problem, any ideas?
Old Sep 18, 2009 | 07:06 PM
erick3's Avatar
are the internal fans on constantly? you'll know right away if your low on coolant. CHECK the nose that runs into the radiator. it should be SOFT. when the car's on, if it's HARD (difficult to squeeze ...sorry) then you may need to burp the system. in that case, wait till the car is COMPLETELY cooled down, open the radiator cap and turn on your cabin a/c FULL blast!
Old Sep 18, 2009 | 08:58 PM
Andruha88's Avatar
SpeedDemon
when this happens ac fans are off,
Old Sep 18, 2009 | 11:16 PM
NAiL05's Avatar
I would check your climate control and make sure your mode is not blowing at your feet. That might cure your issue. As for why its blowing warm it should only be blowing warm when the heater is on.
Old Sep 19, 2009 | 09:09 AM
Andruha88's Avatar
SpeedDemon
my climate control is off, and is still blowing, might stop by mechanic next week
Old Sep 20, 2009 | 06:58 PM
mailman35's Avatar
if your vents/hvac arent set to recirculate then the air will flow through from the outside, matter what, as it has an unimpeded flow.
all past cars i have owned are like this, which is if you dont have the air on and you pop the roof, you will feel air coming out of the dash vents.
if recirculate is on and you are still getting air through the vents then there is something else wrong.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
01CLOwner
Oct 9, 2015 01:07 PM
Sep 14, 2015 10:09 PM
dlknight
Sep 3, 2015 07:54 PM
