Horn Issue
Old Apr 6, 2009 | 04:05 PM
InformativeSilence's Avatar
Horn Issue
I have an Auto 06 TL with about 65K miles. Sometimes I have to really push hard on the horn for it to work...in some cases holding it down until it works. Has anyone had this issue before? Any idea won't the problem could be?
Old Apr 6, 2009 | 08:29 PM
DMZ's Avatar
DMZ
Head a da Family
I've been complaining about this exact problem for the last 3 years. Every time I take the car in, they say there's nothing wrong. Glad to see I'm not alone.
Old Apr 7, 2009 | 10:17 AM
Yep, you're not alone. I wish I knew how to reproduce the problem. It only happens sometimes. I wonder if it's somehow tied to the airbag system because I do notice the airbag light stays on a bit longer (sometimes) than the other lights when starting the car.
Old Apr 10, 2009 | 10:59 AM
Is there anyone else who can provide any feedback here?
Old Apr 10, 2009 | 11:27 AM
sebounet2005's Avatar
TL 2012 SH-AWD TECH/UMBER
Same for me, applying pressure not in the center is easier to horn
Old Aug 16, 2010 | 09:36 AM
TLingham's Avatar
I am having a similar issue and am trying to have this fixed for the 4th time. The dealer is still trying to find the problem. Sometimes it works the first time, sometimes I have pressed it up to 10 times before it works. Daoes anybody think they have the answer to this? Thanks.
Old Oct 25, 2010 | 07:10 PM
JSilver's Avatar
Having this issue as well. Anyone find a fix for this problem?
Old Oct 26, 2010 | 08:21 PM
TLingham's Avatar
Yes! You may search for my post "Horn Problem Solved." I had this problem and finally got it fixed after the dealer spent time with the Acura Tech Line. I was told that the horn was losing its ground. Anyway the solution was to pack special conductive grease into the steering bearing. I was told this is a sealed bearing so it should stay there. My horn has worked perfectly since. Hope this helps.
snorf
Nov 4, 2019 06:44 AM
Frathora
Sep 28, 2015 11:29 PM
Kitsune13
Sep 24, 2015 02:25 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
