Hood keeps closing on me
Old Jan 2, 2010 | 01:30 AM
Etiedeman's Avatar
When I open the hood to my TL it will say open for a bit, but then unexpectidly it will slam closed. I'm not sure what the proper term for the support rods under the hood are. Does anyone have a remedy for my problem? I know I can purchase new supports but I would like to know if there is anything else I can do.
Old Jan 2, 2010 | 01:33 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Purchase new hood shocks, or use something to hold it up, I guess?
Option 1 is the best. That's my recommendation.
Old Jan 2, 2010 | 05:10 PM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
yup...new hood shocks will do it....
Old Jan 2, 2010 | 06:17 PM
shftl's Avatar
New "hood stays," $61.99 plus shipping from Delray Acura. For some reason the left one is more expensive than the right one.
Old Jan 3, 2010 | 09:55 AM
Adobeman's Avatar
The DVD-A Script Guy
If it's extremely cold then that could be it. Either way they are on there way out. You might not need both. It' may be only one has failed.
The old work around is to clamp a vise grip on the shaft, when the hood is up, where the shiny rod enters the cylinder. Many a hatchback owner has left vise grips in the hatch on an ongoing basis rather than spend on new lifters. Most of my Saab 900's needed them
Know that clamping a vise to the shaft will eventually kill the hood lifter if it isn't really dead since you will be damaging the polished surface of the rod which will cut the seals that keep the pressurized gas within.
For a car like the TL I'd replace them. Vice grips complemented a Saab 900 but not an Acura TL.
Old Jan 4, 2010 | 12:50 AM
csmeance's Avatar
I think TEIN makes replacement ones that "fit" our car, I believe a few members have fitted them...
Old Jan 4, 2010 | 01:11 AM
Bender's Avatar
Autozone may even have them. Unless you need name brand ones that are modded.
Old Nov 27, 2013 | 01:02 PM
scottn3's Avatar
Scotch
Has anyone found an aftermarket solution to replacing these gas springs? Mine are out and I'm not liking the $80 option.
Old Nov 27, 2013 | 01:16 PM
Cheapest option:
half kidding..
I got some strongarm lift supports for my Accord a while back and they were solid. CHeaper than OEM too.
Old Nov 27, 2013 | 01:31 PM
350's Avatar
350
My first ricer
Go aftermarket, Strongarm supports are fine and cheap on Rockauto.com. I did the vise grip thing on my old Buick, if the TL hood slams I'll just buy some.
Old Nov 27, 2013 | 02:00 PM
pierceman90's Avatar
i have the same problem... for now im just vice gripping it.
Old Nov 28, 2013 | 12:01 PM
pohljm's Avatar
these struts are like 15$ at the parts store and you really only need one to do the job typically
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Skirmich
Oct 1, 2015 12:59 PM
Bielikb96
Sep 28, 2015 10:45 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
