Highway Blowout - Now ABS-VSA-! Lights On
Had a front passenger blowout last week on the highway going about 80mph (05 TL Auto). After we got back on the road, the ABS, VSA, and (!) lights were on. I did a little research and the likely culprit is that the speed sensor likely got moved or damaged during the blowout. My car is out of warrant and I live 100 miles from the nearest dealer. Is there anyway I can check this myself? Anyone have experience/pictures/diagrams for checking or replacing the speed sensor?
Any other advice would be appreciated.
Thanks!
Thanks!
Try taking the sensor off and inspecting it for damage. Also clean it and the contacts around the axle. Often, these get dirty and throw false warnings. Yours might have gotten hit or something (piece of rubber) may have gotten lodged between the sensor and the axle.
Good luck
Good luck
06 6spd TL BAGGED
i don't know about the tl but the speed sensor was located on the trans. for my integra. it's sticking out and there's a plug that connects to it. hope this helps!
practicing nihilist
It's a wheel speed sensor, not the vehicle speed sensor in the trans. I've never done one in the TL but you should be able to see the wire running to it located near the spindle. Follow the wire, it should be the only electrical item in the area.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
