HID Problem..
Old Mar 25, 2009 | 08:56 AM
capogendon's Avatar
HID Problem..
When I turn my car on sometimes my pass. side headlight is on and sometimes it is off. If it is off.. I turn the headlights on and off again until it pops on.. It is not flickering or anything. I took it to the dealer and they said the bulb is going bad.. Any suggestion on what this could be.
I have an 04 TL (Base) which I bought brand new in 04.
Old Mar 25, 2009 | 09:36 AM
djonyx88's Avatar
onyX.
i have the same problem as you... sometimes my pass hid doesnt turn on... i have to turn on/off many times and not always work... unfortunally i cant take to to the dealer (bought it used off a action) i was thinking it was the igniter and not the bulb bc why would it turn back on like perfect..also i did the conversion to switchback and my driver side has the same problem sometimes its on and sometimes i wont turn on at all... what can we do about this ??
Old Mar 25, 2009 | 09:40 AM
capogendon's Avatar
Hmm.. Not sure. Hopefully someone will come along and help.. cause I dont know what it could be.
Old Mar 25, 2009 | 11:49 AM
gerzand's Avatar
A HID bulb itsself will not fail to ignite unless it has cracked, in which case it would be totally dead or if it is pink in color, which means it is close to the end of it usable life and should be replaced immediately. In your case, it is the Ballast (inverter) or Ignitor (pigtail which leads from the ballast to the bulb) the which is on its way out. I would replace the ballast before it does blow the bulb. Ignitors are less likely to go bad because they aren't exposed to the elements, and are located inside the headlight. Dealer prices for a ballast are about $250-300 a piece. I have a spare fullset for sale in the BST section (will fix both headights) for 200 which also comes with a set of ignitors. Might be worth it if you don't want to be charged crazy $ by the dealer. Check my post in the BST if you decide to go this route.
Old Mar 25, 2009 | 11:52 AM
H-town_Ryda_06's Avatar
TeXas MaDE CusToMz
check all connections.. i had the same problem when i first installed my HIDs cuz i thought everything was tight but i pushed connections even tighter and no more problems
Old Mar 25, 2009 | 12:16 PM
capogendon's Avatar
Thanks.. Would like to see more pics of your ride.. do you have them posted on AZ..
Old Mar 25, 2009 | 12:23 PM
gerzand's Avatar
yeah I have tons of pics posted on the site in various thread topics Ive created. Click on my name to the left <------- and go view my profile and click the "statistics" tab, then "find all threads started by gerzand"
Fool
Mar 10, 2016 08:42 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
