HID help!
Old Jan 3, 2008 | 04:18 PM
BLACKURA_NY's Avatar
I have car ADD
HID help!
So, both of my headlights are lit, but the drivers side Hi-Beam isnt working...
Now, from what i understand, these cars dont use a "dual" filament bulb, its just the way the light reflects. (you put on the hi-beam, the projector opens up a different angle)
So my question is... is the bulb bad? or do I have some other underlaying problems?
Thanks guys!
Old Jan 3, 2008 | 04:21 PM
timmahh's Avatar
it's me, Alan Rickman.
Single bulb, but the HID housing contains a shutter that will open and close, which will expand and contract the light emitted - sounds like your shutter failed, to the dealer for warranty you go!
Old Jan 3, 2008 | 04:28 PM
I have car ADD
fudddgeeee.
cause i just changed the bulbs to 8000k, and they will probably give me shit over this... so im gonna have to put the OEM bulbs back in, and go through the whole process...
could it be i didnt put something back right when i replaced the bulbs? i didnt unplug any connectors, but maybe one "fell" out
does anybody know if there is a wire harness connector for the shutter?
Old Jan 3, 2008 | 04:31 PM
sixsixfour's Avatar
the base of the bulb has a small notch that you line up with the housing socket. if that doesnt match, it is quite possible that when you switched to high beams and the motor moved, the bulb could have been loged in place and/or the mirror/shutter mechanism that moves out of the way could have been damaged/stuck.
it would be best you put things back to stock carefully and see from there.
Old Jan 3, 2008 | 04:36 PM
sixsixfour's Avatar
im not sure, but if you look under/behind the headlight, there is a small connector plugged into the HID housing. its just after where the DRL plug should be (fog on the pre-07 cars) and before the HID ballast plug. that may be the power plug for the motor in case you didnt plug it in that side.
Old Jan 3, 2008 | 04:37 PM
timmahh's Avatar
It's possible if the bulb is upside down or something that and it reaches far enough into the housing that the shutter is being held back, try your OEM bulb on that side and see what happens
Old Jan 3, 2008 | 04:38 PM
I have car ADD
ah ha! that could be the problem. The driver side bulb was a little difficult to get in and manuever, as there is very little room in that section. The passenger side had room, so i made sure everything was locked into place securely.
ugh. back to the drawing board. Do you guys realize what a PITA it is to change these bulbs lol
thanks for the feedback
Old Jan 3, 2008 | 04:39 PM
I have car ADD
OH SHIT !!! JACKPOT
i remember unplugging that connector, and not plugging it back!! im goign to go try that right now
Old Jan 3, 2008 | 04:48 PM
I have car ADD
this is really, and truely the reason why i f'ing LOVE acurazine.... dumbass me, unplugged the connector to try and make more room for my hands, and all i had to do was plug it back!!
now, stupid ass me, went into a panic, and just ordered another set of bulbs that i dont need... so, to the black market those will go !!
sixsixfour, you are the man!
Old Jan 3, 2008 | 05:45 PM
sixsixfour's Avatar
lol you're welcome.
you know how i found out what that connector was? i was tinkering around under the hood to see which was which, and i saw that plug. unplugged it and turned on the HIDs. no effect. i then thought to myself ""could be for the motor for the high beams" but never really checked.
guess i was right.
glad I can help a fellow WDP
Old Jan 3, 2008 | 05:47 PM
I have car ADD
lol.. fellow WDP'er, with the tag name of BLACKURA
thanks again man... now im going to compare my 8000k to 8500k and see which one i like better
Old Jan 3, 2008 | 07:04 PM
vinnier6's Avatar
what was wrong with the stock ones....
Old Jan 3, 2008 | 07:23 PM
lenjaiah's Avatar
hey blackura!!! wanna help me change out my bulbs when the weather gets warrmer???
Old Jan 3, 2008 | 07:27 PM
I have car ADD
nothing, i just wanted to upgrade to a different temperature. the color and cutoff lines are amazing with higher temp. bulbs
Old Jan 3, 2008 | 07:28 PM
I have car ADD
sure, where do ya live? its not the hardest thing in the world. just need to make sure you disconnect ALL power to the HIDs.... 25,000 volts can and WILL kill you if you make a mistake...
Old Jan 3, 2008 | 08:49 PM
timmahh's Avatar
Also don't forget to plug in the connector for the projector shutter, failure to do so will cause sudden panic, resulting in posting on Acurazine about a possible housing problem, which results in further panic causing you to order an additional set of bulbs and prepare to reinstall your OEM bulbs
Well that's a bit much, what are the odds of that happening?
:p
Old Jan 3, 2008 | 09:07 PM
lenjaiah's Avatar
I live near the cross island/little neck. hmmm dont u have to take off the bumper or the fender liner? i read a few threads and it doesnt look that simple.. i will give it a try this weekend. btw.. did u disconnect the battery? plus all other wires? or just the HID itself?
Old Jan 3, 2008 | 11:52 PM
I have car ADD
DEFINITELY disconnect the battery..,. otherwise.. your fried
outta curiosity.. what color car do you have? i always see a WDP with some chromie's and type s tails on little neck, near the grand central & union tpke.
Old Jan 3, 2008 | 11:55 PM
I have car ADD
:p
ha ha
look man, i've baked and blacked out over 15 sets of 3G headlights for members, but i never changed the HID bulbs because of that little sticker that says 25,000 volts CAN KILL
i just realized now, all you really gotta do is unplug the battery,and there wont be any volts!
<-- in a dumb fog for the past 2 years
Old Jan 4, 2008 | 12:32 PM
lenjaiah's Avatar
i got a WDP type-s. i think i know which car ur talking about. wanna do a meet this weekend? if it gets warmerrr that is..
Old Jan 4, 2008 | 01:22 PM
I have car ADD
Sure... I am free this weekend, supposed to be like 40 degrees. PM, as i might also have some bulbs i can install for you if you need.
Old Jan 20, 2008 | 07:28 PM
Mosclipse11's Avatar
3rd Gear
Hey Blackura... I would like some help baking n blackening my headlights
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
