HID help!
HID help!
So, both of my headlights are lit, but the drivers side Hi-Beam isnt working...
Now, from what i understand, these cars dont use a "dual" filament bulb, its just the way the light reflects. (you put on the hi-beam, the projector opens up a different angle)
So my question is... is the bulb bad? or do I have some other underlaying problems?
Thanks guys!
Thanks guys!
it's me, Alan Rickman.
Single bulb, but the HID housing contains a shutter that will open and close, which will expand and contract the light emitted - sounds like your shutter failed, to the dealer for warranty you go!
fudddgeeee.
cause i just changed the bulbs to 8000k, and they will probably give me shit over this... so im gonna have to put the OEM bulbs back in, and go through the whole process...
could it be i didnt put something back right when i replaced the bulbs? i didnt unplug any connectors, but maybe one "fell" out
does anybody know if there is a wire harness connector for the shutter?
the base of the bulb has a small notch that you line up with the housing socket. if that doesnt match, it is quite possible that when you switched to high beams and the motor moved, the bulb could have been loged in place and/or the mirror/shutter mechanism that moves out of the way could have been damaged/stuck.
it would be best you put things back to stock carefully and see from there.
It's possible if the bulb is upside down or something that and it reaches far enough into the housing that the shutter is being held back, try your OEM bulb on that side and see what happens
ah ha! that could be the problem. The driver side bulb was a little difficult to get in and manuever, as there is very little room in that section. The passenger side had room, so i made sure everything was locked into place securely.
ugh. back to the drawing board. Do you guys realize what a PITA it is to change these bulbs lol
thanks for the feedback
Originally Posted by sixsixfour
im not sure, but if you look under/behind the headlight, there is a small connector plugged into the HID housing. its just after where the DRL plug should be (fog on the pre-07 cars) and before the HID ballast plug. that may be the power plug for the motor in case you didnt plug it in that side.
i remember unplugging that connector, and not plugging it back!! im goign to go try that right now
this is really, and truely the reason why i f'ing LOVE acurazine.... dumbass me, unplugged the connector to try and make more room for my hands, and all i had to do was plug it back!!
now, stupid ass me, went into a panic, and just ordered another set of bulbs that i dont need... so, to the black market those will go !!
sixsixfour, you are the man!
you know how i found out what that connector was? i was tinkering around under the hood to see which was which, and i saw that plug. unplugged it and turned on the HIDs. no effect. i then thought to myself ""could be for the motor for the high beams" but never really checked.
guess i was right.
glad I can help a fellow WDP
Originally Posted by lenjaiah
hey blackura!!! wanna help me change out my bulbs when the weather gets warrmer???
Also don't forget to plug in the connector for the projector shutter, failure to do so will cause sudden panic, resulting in posting on Acurazine about a possible housing problem, which results in further panic causing you to order an additional set of bulbs and prepare to reinstall your OEM bulbs
Well that's a bit much, what are the odds of that happening?
:p
:p
sure, where do ya live? its not the hardest thing in the world. just need to make sure you disconnect ALL power to the HIDs.... 25,000 volts can and WILL kill you if you make a mistake...
:p
:p
look man, i've baked and blacked out over 15 sets of 3G headlights for members, but i never changed the HID bulbs because of that little sticker that says 25,000 volts CAN KILL
i just realized now, all you really gotta do is unplug the battery,and there wont be any volts!
<-- in a dumb fog for the past 2 years
