HID Fogs
Old Apr 29, 2011 | 04:54 PM
Gnargasim's Avatar
HID Fogs
I just purchased a set of HID3000k fogs for my type s. i installed the front left first, test them and they worked, then the front right and they worked. Went out for a little bit came back and the fogs were not working any more i checked the fuse and it was blown and now only the front right works. I noticed that in the fuse box it FR FOG for the fuse i was wondering if the front left was on a separate fuse than that other.
Any suggestions?
Is there an inline fuse or something i dont know about with HIDs or the wiring of the fogs
Old May 2, 2011 | 05:08 PM
Gnargasim's Avatar
sooooooo
Old May 2, 2011 | 05:56 PM
95oRANGEcRUSH's Avatar
KBPftmfw
Both lights run on the same fuse and it's rated a 10A. Step it up to a 15A and you'll be fine.
Old May 2, 2011 | 06:10 PM
dzionny_dzionassi's Avatar
its only one fuse, i had same problem but my both lights were out, try to put 15amp fuse. That solved my problem. I hope that helps.
Old May 2, 2011 | 08:30 PM
dwb993's Avatar
Are you using a relay harness? If not, go spend the $20 for one and wire them up through the harness. Stepping your fuse up to 15A is not best practice with electricity. The puny OEM wires cannot handle that load which is why the fuse is blowing.
Old May 3, 2011 | 10:40 AM
MattB07TL's Avatar
^^+1 had the same issue. 3k's worked for a little bit and blew the fuse.Then tried running a little bigger fuse which is stupid and dangerous and that didn't work.so went with the relay harness and that fixed the issue.
Old May 3, 2011 | 11:04 AM
Elite1982's Avatar
i had the same issue... my fuse blew out and stepped it up to 15a... also, a harness will make the fogs brighter than the 15a could...
Jul 16, 2017 07:33 AM
Avenger411
Oct 11, 2015 03:53 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
