HELP! VLED DRL Harness creates DRL warning light?
BluePearl
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Sorry for creating a new thread on this. I have a 2007 TL-S.
I just installed the harness today, and my DRL warning light comes on everytime. I followed the instructions for connecting resistor harness to the original factory connector, then connecting the resistor harness output to the relay harness, then the led bulbs go onto the relay harness. But I have a DRL warning... What am I doing wrong?
Also, do you guys know if I can put a regular bulb in for the LED, maybe that will make the light go away but still have the full power? I know someone mentioned full power halogens might burn the housing?
Check the connections
Hi, try double checking the connection to the DRL power. Someone on this thread had the same issue, the connection was reversed which was causing the DRL warning light.
https://acurazine.com/forums/3g-tl-2004-2008-93/v-led-new-drl-harness-784319/
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
Skirmich
09-15-2015 06:41 PM
