Help with Temp Gauge
I recently swapped my 04 cluster for a 07. Everything seems to working fine except the temp gauge. At normal operating temp, it sits abnormally low. I tried adjusting it, but that only created more problems. Has anyone else had this problem?
Haven't heard of this problem, it should be plug and play.
Some might not be up for it, but if you still have your 04 cluster, check to see what it's minimum point is.
Then check your 08 and see where it's minimum point is.
If the 08's minimum point is way too low, that would be your problem. Take the needle out (they pop in and out) and re-position it correct to match the 04.
While you're at it, tape off the TPMS light LED.
justnspace (11-27-2017)
