Help with strange intermittent electrical problems
Old Mar 7, 2011 | 11:07 PM
xrochester's Avatar
'04 TL is experiencing strange, intermittent electrical issues such as turn signals not working, outside temp guage not showing anything, dash brightness going from bright to dim, hand free link not working, keyless entry would unlock car but wouldn't flash lights. Any ideas would be greatly appreciated.
Old Mar 7, 2011 | 11:19 PM
xrochester's Avatar
PS - just to clarify, then everything just starts working properly again. It's off and on.
Old Mar 12, 2011 | 01:15 AM
05TLbase's Avatar
with all those different circuits screwing up Im guessing a lead on the battery is loose, or the chasis ground from the battery. Make sure theyre all tight.
Old Mar 15, 2011 | 07:45 PM
ghostsixone's Avatar
8th Gear
I am having this same exact problem, just started today. I have an 05 TL. Dunno wtf is going on with this pos car, but I've lost all respect for Acura when a car like this has this magnitude of failure. I'm already dealing with my driver's side actuator not working. I can't even drive this car now since it appears my rear defrost doesn't work either.
Things not working:
Fog Lights will not work.
Dash headlight indicator is out, but headlights turn on.
TURN SIGNALS DO NOT WORK.
Outside Temp Gauge is out.
Windshield wipers only work on max.
Gauges do not toggle between MAX BRIGHTNESS and normal brightness when I turn on the headlights - almost like the car doesn't know the lights are on.
This is complete BS, and shouldn't be happening.
Probably are other things not working, but that's the big stuff I've noticed thus far.
Old Mar 15, 2011 | 09:38 PM
8th Gear
Just discovered I cannot open my trunk either because my key fobs don't work anymore. I can't even open the rear doors of the car at this point without climbing back in there.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Brandle34
Sep 23, 2015 07:20 PM
