Help: sometimes my car won't start.
Old Sep 15, 2018 | 08:25 AM
eastvantrading's Avatar
Hi everyone,
There were no replies to my previous post, but here goes again. Hopefully I can be more succinct and clear and get some answers.
My 2006 AT base (80K kms) has been having trouble starting for the past 2 weeks. Car fails to start about 1 out of 10 times.
Lights & radio etc. all seem fine. When I turn the key, I get the relay rapid click/buzzing sound by the fuse box then a click and nothing.
Shifting gears doesn't help. Neither does swapping keys. Just random.
Checked battery (new 1 year), cables, & fuses (visually). Swapped some of the identical relays. Tried tapping the starter but that did not seem to do anything.
I replaced the ignition switch and that got rid of the relay clicking/buzzing sound (yay?) but still get the occasional non-start, though it seems like it's less frequent. Single click and silence...no start.
The previous owner had the hands-free disconnected.
My next move is to try replacing the starter with a midrange aftermarket. Someone suggested I just change the starter solenoid, but it seems like a solenoid itself is harder to find and almost the cost of a new starter and probably the same amount of work. Can anyone think of anything else to check? I'm worried that if I leave it, I will be stranded somewhere, so I'd really like to fix it.
Thank you!
Last edited by eastvantrading; Sep 15, 2018 at 08:35 AM. Reason: added detail re: HFL
Old Sep 15, 2018 | 10:40 AM
rockauto.com or amazon.com for a DENSO remanufactuered starter.
Old Sep 15, 2018 | 12:05 PM
Hmm, I'm in Canada so options are limited. Rebuilt Denso starts at $300. Any other recommendations? Thoughts on AC Delco?
Old Sep 15, 2018 | 03:04 PM
I personally only go reman OEM or OEM. Can't speak on aftermarket ones . Just try it
Old Sep 16, 2018 | 09:19 AM
Found a Denso on Rockauto for $250 Canadian with shipping!
That includes $110 core, though international return shipping will probably kill that.
Old Sep 16, 2018 | 10:27 AM
vpasla1's Avatar
I don't think shipping will be too bad, the starter isn't exactly a big or heavy part. Rockauto makes it easy to ship back with a shipping label you can print out.
Old Sep 16, 2018 | 09:53 PM
DMZ's Avatar
DMZ
Head a da Family
Have you tried replacing the + battery cable? At this age it may be corroded internally where you can't see and can easily cause these types of issues.
Old Sep 20, 2018 | 12:07 PM
replaced
Received Denso reman starter from Rock Auto. Replaced it in about an hour and half (could have been 30 min - see below) using only hand tools and without lifting the car. My engine bay is pretty clean so I didn’t expect too much trouble with bolts etc.
Not a lot of fun though. Worst part as many have reported was removing the battery tray. Though in my case I spent about an hour putting it back. Stripped one of the upper bolts somehow and lost another in the engine bay
Old Oct 29, 2018 | 05:02 PM
Father of Seven's Avatar
Problem solved? Thanks.
Old Oct 29, 2018 | 05:52 PM
Yes, solved...so far so good!
Shaqs2002TLS
Oct 24, 2014 07:00 AM
tr59210
Feb 7, 2013 06:24 PM
4ank
Jul 7, 2010 06:42 AM
