Help! Rear interior dome LED not working...
Old Jan 23, 2009 | 09:35 AM
chadwikki's Avatar
So I just got my interior dome and door LEDs from superbrightleds.com and was changing them out. For some reason the rear passenger dome light does not come on though. I tried all four LEDs in there and none of them worked, but they work fine in other three dome lights. I also put back in the original factory lightbulb and that worked just fine, so I'm at a loss when it comes to troubleshooting this any further.
I thought I remembered hearing this problem in one of the other threads on changing out LEDs, but there are so many freakin posts I could've remember where I found it. Any suggestions would be appreciated!
Old Jan 23, 2009 | 10:47 AM
Jawbone's Avatar
I know this may sound silly but I had the same problem until I turned the bulbs around. I think the bulbs only go one way so if it doesn't light up insert them the other way. Good luck.
Old Jan 23, 2009 | 11:48 AM
Trew's Avatar
^ That's precisely what his problem is. Just spin the bulb 180 degrees and put it back in.
Old Jan 23, 2009 | 12:44 PM
Majofo's Avatar
LED = Diode so current flows one way due to reverse voltage blocking so the convention of the applied voltage polarity matters. Whereas a regular bulb is typically just a filament = Resistor and its polarity convention doesn't matter because current can flow either direction.. (just a little more info..)
Old Jan 27, 2009 | 10:07 AM
chadwikki's Avatar
Sweet, I tried turning it around and it worked right away! Man, what's the chances that I tried all four bulbs and had them all turned the wrong way??? Oh well...thanks for helps fellas!
Old Jan 27, 2009 | 10:53 AM
Majofo's Avatar
Nice..
Feb 25, 2020 09:57 AM
oyayjoe
Jan 1, 2019 10:17 PM
handsom-hustla
Nov 13, 2015 05:04 PM
oyayjoe
Sep 12, 2015 04:40 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
