help please
Old Nov 18, 2009 | 07:14 PM
bukjoe15's Avatar
help please
Hi I'm a TL owner. I know this is the TL section but I could not find the Acura Integra section but can someone transfer this topic to where it belongs thanks. Well my problem is passing emissions. I took my 1996 Acura Integra RS to get SMOG tested twice, first time I FAIL with bad O2 sensor and Evap Emission Control system pressure Sensor “code number P0453”, I fixed the O2 and reset the codes hoping I would pass the second time but I failed EVAP sensor again. Do I change the sensors or how would I go about fixing this problem???? PLEASE HELP and if sensor needs to be change; where is the sensor? I know where the Evap canister is located and the purge sensor. BUT couldn’t find the EVAP sensor. Some technician said I have to change the fuel pressure sensor and I told him this car does not have one. I believe they didn’t come out with a FPS until 1999 or 00 Integras but I might be wrong.
Old Nov 19, 2009 | 08:50 AM
LoveMyTL-S's Avatar
We don't have an Integra section. But perhaps someone can help you that knows Integra's.
Old Nov 19, 2009 | 11:56 AM
Majofo's Avatar
RSX would be closest forum.. you should PM Stillhere.. I'm not sure of the pressure sensors location on the tank / fill neck but I'm sure it should be fairly easy to diagnose / replace.
A P0453 DTC trouble code may be caused by one or more of the following:
  • Open on FTP sensor signal wire
  • Short to voltage on FTP sensor signal wire
  • Bad FTP sensor
  • Abnormally high pressure in fuel tank due to blockage in EVAP purge hoses or overfilled tank
  • Loose/damaged FTP sensor connector
  • Loss of ground to the sensor
^ http://www.obd-codes.com/p0453
Old Nov 19, 2009 | 07:53 PM
bukjoe15's Avatar
Thanks for not removing my post, but I have been reading and becoming confused about this sensor. Is the FTP and EVAP sensor the same sensor? I also have read that the 1996 RS Integra does not have a FTP sensor. Only 1996 GSR and UP and 1996 LS. But if there is any more information it would be nice thanks.
